Author Topic: Water Choke Not Working... Solved Thanks!  (Read 2456 times)
i_luv_my_truck
  • Turtle Points: -48
  • Male Posts: 157
  • Member since Mar '05
  • Toyota Crawler
    • My Rig
« on: Aug 09, 2006, 06:38:39 PM »
Good Evening, maybe someone can assist.
Toyota 20R 4X4 1980, relatively stock.  The water choke is not working properly.  I've diagnose the water is not heating up in that area.  Looks like there are two positive flows of water to the choke, cancelling out each other.
The Heater does not show to get hot either.
Can someone kindly inform the proper connections?
There is one outlet/inlet(?) on back of timing cover (passenger side).  Does that go to heater or choke?
There is one outlet/inlet(?) on head behind intake manifold.    Does that go to heater or choke?
There is one, what appears to be an outlet, that goes straight up from intake manifold, I'm pretty sure that goes to the choke.
Thanks in advance for any information. :)
Ernest
« Last Edit: Aug 12, 2006, 07:51:15 PM by i_luv_my_truck »
1977 Toyota Hilux 2wd - because because
1980 Toyota Hilux 4x4 - restoration project
1981 Toyota Trekker - nostalgia
1982 Toyota Hilux 4X4 LB - just because
1984 Toyota Hilux 4X4 - everyday driver
2001 Toyota MR2 Spyder - for speed
1993 Toyota Previa - for relaxing
http://www.cardomain.com/ride/2093325/
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Water Choke Not Working. But... Help Please
« Reply #1 on: Aug 09, 2006, 07:05:00 PM »
side of the head is the choke  and timing cover goes to heater
:headscratch:  i think,
« Reply #2 on: Aug 09, 2006, 07:06:10 PM »
your gonna make me go look in the dark aint ya  :down:  ok be back in a minute  :bolt:
« Reply #3 on: Aug 09, 2006, 07:11:25 PM »
ok timing cover goes to choke, then choke goes into top of intake,
side of head goes to heater
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
« Reply #4 on: Aug 10, 2006, 12:20:15 AM »
Thanks alot!! "79Coyotefrg" that helped alot.  I had them transposed, they're both in the same area.  Now my choke is working properly and truck is running like a top!  :clap2:
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Water Choke Not Working. But... Solved Thanks!
« Reply #5 on: Aug 10, 2006, 12:41:53 AM »
Wow, this got solved before I could read it hahah nice
Last post Nov 01, 2007, 08:37:33 PM
by 82rustbeast
Last post Jun 27, 2010, 10:15:18 PM
by DeMented Toys
Last post Dec 15, 2010, 02:57:43 PM
by 80firstgem
Last post Jan 18, 2011, 07:51:26 PM
by JoeWelder
Last post Jan 17, 2017, 04:46:21 PM
by Cavu2usf
