Author Topic: 20R water choke bypass?  (Read 4880 times)
YotaJosh
  • Male Posts: 499
« on: Dec 01, 2009, 11:11:46 AM »
Is it possible to completely bypass the water choke hoses on a 20R by plugging the port on the intake and the connection under the intake?
Currently I have a PVC male/male connector in the place of the water choke since I've got a carb with elec. choke, but I'd like to remove the entire hose all together.
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Re: 20R water choke bypass?
« Reply #1 on: Dec 01, 2009, 08:39:36 PM »
yes you can, just plug the intake hole and run the hose from the one under the intake to the heater core
:headscratch:
« Reply #2 on: Dec 01, 2009, 08:43:41 PM »
I can get you a pic of mine tomorrow if ya want.
YotaJosh [OP]
  • Male Posts: 499
« Reply #3 on: Dec 02, 2009, 10:01:40 AM »
A picture would help if you can.
So you are saying I can run a hose from the water pump outlet under the intake (where the water choke hose is now) to the heater core? Right now the heater core is connected to the other outlet under the intake, that runs into the side of the head. Can I block that port off?
« Reply #4 on: Dec 02, 2009, 11:46:44 AM »
no, dont block that port off,  i'll get a pic :bolt:
motormouth559
  • Male Posts: 917
  • Member since Oct '07
« Reply #5 on: Jan 06, 2010, 11:03:09 PM »
X2 i need pics of that
YotaJosh [OP]
  • Male Posts: 499
« Reply #6 on: Jan 07, 2010, 06:23:33 AM »
I actually figured it out.
Underneath the intake, there is a temp activated vacuum tee. I unscrewed that, put in a 3/8 90* elbow and a 3/8 straight nipple from Home Depot. Doing this allowed me to use the factory elbow shaped hose that was part of the water choke (from the carb to the top of the intake), and connect the new inlet with the water pump outlet under the intake. Then I plugged the old location on top of the intake with a 1/2 pipe plug.
I'll try to get a picture.
DeMented Toys
  • Turtle Points: 160
  • Male Posts: 1,151
  • Member since Aug '04
  • Woo-Hoo!!!
« Reply #7 on: Jun 27, 2010, 10:15:18 PM »
Got that picute yet?   :dunno:
Jeff DeMent
-DeMented Toys-
Last post Aug 10, 2006, 12:41:53 AM
by BigMike
Last post Aug 25, 2009, 04:27:20 PM
by badshark
Last post Dec 15, 2010, 02:57:43 PM
by 80firstgem
Last post Feb 14, 2012, 01:59:24 PM
by IronClad
Last post Jan 17, 2017, 04:46:21 PM
by Cavu2usf
