Author Topic: 22r engine knock  (Read 1682 times)
Keithporter83
  • Member since Jun '15
22r engine knock
« on: Jul 18, 2015, 07:17:30 AM »
I have a 83 pickup and it started knocking real bad the thing is it only knocks after you drive and for about 5 mins and get it warm. I cant really pin point were it is coming from it gets worse when you rev it and you can kinda get that mid point in throttle were the knocking gets super bad. I pulled the valve cover and the timing chain looks good. what should I look for the pin point were its coming from I hope its not a rod or main knock but if it is I can deal with that its a trail rig so it not like I cant get to work.
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: 22r engine knock
« Reply #1 on: Jul 21, 2015, 07:50:29 AM »
Rebuild that sucker before it spins a bearing.
– Steve McQueen
nwflyoda
  • Turtle Points: 36
  • Male Posts: 271
  • Mall Crawler
« Reply #2 on: Jul 21, 2015, 07:58:24 AM »
It wouldn't hurt to rebuild the motor before it causes any major damage.
84 Yota Pebble Pounder
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #3 on: Jul 21, 2015, 12:10:45 PM »
If it sounds like a real loud valve tap, and seems to be coming from the top end, it is likely the rod bearings.  Seems counter intuitive, but I went through this last year with an '85 I restored.  Checked everything out, ended up dropping the pan, and found 1 & 4 rod ends loose.
What my 22re rod issue sounded like.
« Last Edit: Jul 21, 2015, 05:26:07 PM by Snowtoy »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: Jul 24, 2015, 06:45:42 PM »
sounds like wrist pin knock.  basically the piston wants to separate from the rod end.  if it has good compression I'd pull it down and have new bushings installed in the rods and install new rod and main bearings because if the wrist pins are that bad so are the bearings :(
OR just run 20w50 Castrol GTX and dont try to rev to 6000 rpm.
Last post Feb 16, 2004, 09:02:47 AM
by brainlessfool
Last post Oct 12, 2007, 08:10:30 PM
by havik
Last post Jul 27, 2007, 03:19:22 PM
by AaronB
Last post Dec 20, 2009, 11:06:05 PM
by mr.charli3
Last post Jan 11, 2010, 08:55:56 PM
by axled89
