KWP's 92 4Runner build ( finished front tube pics)
Started by KWP, March 27, 2005, 04:35:27 PM
KWP
I've finally got a few updates. I started geting all of my parts in Friday so I've gotten to work on it some. The front 60 is torn down to get cleaned and regeared, front spring hanger is built and welded on,and front shackles are almost done. I left my digi at my dads shop so no pics until tomarrow.
Stuff left to do
Tear down rear 60 to clean and regear.
Install rear disk brakes.
Machine high stear arms.
Build square front dshaft
Build rear dshaft and have ballanced.
Install 3/4 ton chevy master cylinder
Install proportioning valve, and lots of misc stuff.
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
alwaysbroken
89 4 Runner, 3.0, 5spd, 2.28 crawl box, 4-1 atlas, prorock 60 up front, crd60 out back, on 37" mtr's
Tweeked89
W.H.O.R.E. founding member
-My G-Ride-[/b]
89 Ex-cab Toyota, V6, Locked Dana 60s, new 39" IROKS, kinda built kinda not
FatAzzRunner
Hey man, Sweet build up by the way.  Are you in OK?? Where at?
Also, PLEEEEEEEAAAAAAASSSSSSSSEEEEEEEEEE  PM me if you are interested in sellin your current Yota running gear and beadlocks for the Yota.
I am wanting some beadlocks really badly.
Thanks
Aaron
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
Thumper
Hey arron sorry i beat ya too the beadlocks i bought them a couple of weeks ago and im trying too buy the axels now if they are not traded off for a 60 ft.
marsh racing wheels in ark has some good deals on custom beadlocks they are pretty good on prices too. might look them up and call them about some beadlocks.
good luck
thanks
adam
FatAzzRunner
DAMMMMITTTTT!!!  Ok, I appreciate you lettin me know.  I am always a day late or a couple hundred dollars short when good stuff comes up for sale.
:smack:
whiteman
Pretty sweet looking tires.  Nice job on the bobed top, any plans for the bed?
KWP
Quote from: whiteman on January 30, 2006, 04:46:28 PM
Thanks, as far as the bed the only thing i'm going to do now is just build the soft top to cover it. I might bob it later if I have trouble hanging it on stuff. I can't go much due to the F150 springs. The rear hangers are going to be almost to the end of the frame.
KWP
 I got a few update pics. This thing is going to be wide.
FatAzzRunner
HOE-LEE-CRAP!!!!!!!!!!!!   That thing is gonna be huge.
Quick question, how much you think your gonna have wrapped up in the axles, tires and wheels when your done.  I am talking about the COMPLETE axles and anything related to the swap.
Thanks
KWP
Quote from: FatAzzRunner on February 01, 2006, 02:17:58 AM
Thanks
I don't have a whole lot in them, could be alot more. I still need to machine the hubs and build my high steer arms. Here's a list :biggthumpup:
  Wheels and tires  $1200
  Front axle  $800
  Gears and installs $580
  Rear axle  FREE
  rear disk brake parts $150
  Lots of other misc stuff that I havn't gotten yet but that's the majority of it
whiteman
 :thumbsup:  Awsome, those axles and tires are going to make that thing look evil.  What springs are you running up front?
KWP
Quote from: whiteman on February 01, 2006, 03:52:07 PM
In that pic the axle is just sitting under it but I am making a pack with a mix of 3'' Downey fronts and 3'' Downey rears. I built them today so I should have them under it tomarrow. :thumbs:
KWP
I've finally got the front sitting on its own weight again. I guess I need to put a 2'' body lift under it to help clear the tires a little better. The spring pack I built didn't quite give me enough lift.
whiteman
Nonsence, hack the fenders out you'll be fine... :gap:
That shits gonna flex like a mutha, all that leverag...  whoa yeah.
eightyfive
whoa! nice........you should make it so you can still use the rear window!
._________________________________________.
||____________||____________||___T0Y0TA__||
||____________||____________||____________||
1985 TOYOTA 4RUNNER
some modifications here and there....
motorider228
are the axles already geared? or do they need to have the gears put in?
KWP
Quote from: motorider228 on February 02, 2006, 08:56:42 PM
I regeared them to 5.38 :thumbs:
KWP
Quote from: eightyfive on February 02, 2006, 08:14:46 PM
I had thought about that when I first started cutting but it seemed like it would be more work than what it was worth.
KWP
Quote from: whiteman on February 02, 2006, 06:01:57 PM
Hell yea, this thing should flex like crazy :biggthumpup: I still need to machine the hubs to narrow it up some, just a little to wide.
BoMXtreme
I didnt know a Dana 60 is that wide! Do they come in different widths or is that the only width available.
Looking for 35s in SLO later summer time, like august.  Swapping Tires??
whiteman
Dana 60's are full size axles, unless there is some trick ass rig on the market I dont know about they are all in close proximity from each leading manufacturer of trucks.
KWP
Quote from: BoMXtreme on February 02, 2006, 11:21:53 PM
The 60 I have under there is a dually axle which is wider than a single rear wheel axle. I am going to machine the hubs down so that it will be the same width as a SRW front. It's just way to wide as it is now.
whiteman
KWP
Quote from: whiteman on February 03, 2006, 08:21:20 PM
Hows that rear coming?
I'm picking it up tomarrow to tear down and regear :biggthumpup: . It's under a 3/4 ton Dodge at my uncles house and he's been gone so I haven't been able to get it.
whiteman
KWP
Quote from: whiteman on February 07, 2006, 08:20:01 AM
...... :inthedark: .....are you there....any new, new's.
Nothing much new. I started a new welding job and have been working long hours so I haven't been able to work on the pile. I did get my rear 60 home so I should be able to do a little on it in the evenings. I'll have pics of it up tomarrow.
BoMXtreme
Do any companies sell adaptors so for instance a Dana 60 axle and its driveline can be mounted to a Toy box?  Or do you just go ahead and weld the flanges together?
Ramrod
someone makes a new pinion flange so you can use a toy driveshaft on a 60
KWP
High angle driveline makes the pinion yoke for the 60 to toy but I am building my own driveshafts :gap:
