Author Topic: 22re wont crank  (Read 3336 times)
zach0786
  • Member since Feb '15
22re wont crank
« on: Mar 31, 2015, 03:24:48 AM »
Working on fixing 89 4runner sputtered and backfires running rich. Loosened distributor and barely moved it now it wont crank. Could have thrown timing off by just barely moving it?. Also noticed that im not getting any fuel in fuel filter.  What could this be other than fuel pump.
OVRAROK
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Re: 22re wont crank
« Reply #1 on: Mar 31, 2015, 06:32:17 AM »
Could be bad afm,did you jump the two connectors to rule out fuel pump. The afm sends signal to fuel pump. Also I would set motor at #1 cylinder, and reset timing
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: 22re wont crank
« Reply #2 on: Mar 31, 2015, 12:06:39 PM »
Imagine if it was already sputtering and running rich because your timing was retarded by 5-degrees. Now by barely moving it you've gone another 2 or 3 degrees and suddenly you're almost 10 degrees retarded. Definitely start with setting the timing with a timing gun properly. You at least know this must be correct so it is where I'd start with troubleshooting.
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: 22re wont crank
« Reply #3 on: Apr 01, 2015, 10:04:41 PM »
You say it won't crank after moving the distributor?  So the engine will not turn over?  Definitely something else wrong.
Otherwise, if it's turning over, do as Mike said.  You have to have a baseline to start with.  3 main things you need are air, fuel and spark.  I usually systematically eliminate each as a potential problem until you find one isn't being properly delivered or produced.
zach0786 [OP]
Re: 22re wont crank
« Reply #4 on: Apr 02, 2015, 07:49:38 PM »
Timing was out 180degrees. Fixed it . Now it cranks but still having problem when driving bogging down when accelerating. Sluggish  and backfires. Reset codes then checked computer for codes again  got 5 codes i noticed all the codes say ECM as a cause. Im wondering if its bad.Can it be reset? Also engine was cranked and i unplugged TPS nothing happened. Could TPS be the problem. Its looking like there's no cheap way outta this one.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: 22re wont crank
« Reply #5 on: Apr 02, 2015, 09:28:16 PM »
Sounds like you need to go thru all the sensors with a Ohm meter and the Factory Service Manual.
zach0786 [OP]
Re: 22re wont crank
« Reply #6 on: Apr 03, 2015, 09:50:57 PM »
I have Haynes manual ain't worth a damn btw. Or do i need factory manual.  Where do I find one vehicle didn't have one when I bought it
Cheesemaker
  • Male Posts: 4,525
Re: 22re wont crank
« Reply #7 on: Apr 04, 2015, 04:09:37 PM »
You can get a FSM from these guys.  For an extra $15.00 iirc, you can get a VIN specific wiring schematic.  The FSM is like over $100, worth every penny.
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton, CA 90220-5538 USA
1-800-622-2033
(outside CA)(M-F: 7-5 PST)
1-800-443-7656 (inside CA)
1-310-818-4630 (in or outside CA)
The p/n for my 1985 Truck & 4Runner
There are some PDF files for free online, but some are missing, and many have been taken down over the years.
Last post Apr 16, 2006, 08:52:00 PM
by bigburb
Last post Jun 13, 2006, 06:48:00 PM
by AzBearFan
Last post Oct 24, 2007, 01:39:29 PM
by y-townxj
Last post Jul 27, 2009, 11:08:08 AM
by *ROKTOY*
Last post Oct 09, 2015, 09:20:44 AM
by OVRAROK
