89 Toyota Pickup project!
Started by Rusty78364, January 19, 2015, 08:04:20 PM
LittleSteve
Dingman works for high angle.....
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
Quote from: LittleSteve on February 09, 2015, 07:54:21 AM
That's right! I forgot that he works there.
H8PVMNT
The world becomes so much flatter when you get SASed!  I like your coating. Is this a bedliner product?
– Steve McQueen
4xChinook4
Great build man. Enjoy the SAS once you finish it. :thumbs-up:
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
Rusty78364
Quote from: helipilot77 on February 08, 2015, 10:42:38 PM
Only way I have ever gotten them off is with two 14mm end wrenches. You are right there isn't enough room for a ratchet. I have heard that you can take the yoke apart and grind on it to get more angle out of it. High angle driveline can make a brand new driveline for you application if you have the money.
I was able to use a shallow socket with a wobbly extension and get in there, just gotta find the sweet spot as far as clearance. Once it broke loose then you can loosen it by hand and take the bolt out. And i think im gonna get a custom long slip driveline made by either tom woods or Drivelines northwest, my company has an account with drivelines northwest so we will see how much it is haha
Rusty78364
Btw got the swap done but it was too dark to post pictures, will post pictures tomorrow! :)
Rusty78364
Quote from: H8PVMNT on February 09, 2015, 01:27:27 PM
Its a product called zero rust, i bought it at Tacoma screw they said its super durable and its a DTM product (direct to metal) so prep was just getting the old paint off and then cleaning the surface then painting. So far im happy with it, i think it looks good and so far its held up
SqWADoosh
What did you end up doing about your drive shaft?
Dingman.
Quote from: Rusty78364 on February 09, 2015, 09:31:56 PM
Ouch, that cuts deep..   lol
Rusty78364
So ended up talking with drivelines northwest and they reccomend going the trail gear route for off roading, they said they just cant beat that price so what have you guys heard about the trail gear heavy duty driveline kit? Good or bad?
Rusty78364
Never mind totally blanked, even if i got the trail gear kit my driveline wont droop enough, looks like its gonna be a tom woods driveline!!! Haha
1985CRAWLER
Quote from: Rusty78364 on February 10, 2015, 09:30:26 PM
:smack:
i wouldnt buy their kit
call high angle! they were getting tons of business for KOH rigs/buggies!
helipilot77
I wouldn't recommend using trail mart u joints. I have them on my truck right now. I bought some as trail spares. They vibrate horribly at highway speeds. Best to use the factory u-joint.
SqWADoosh
He was given some advice by a buddy at work to have a CV on both sides of his front drive shaft. I was telling him last night that it is complete and utter overkill to do so. He really only needs one at the transfer-case output. I think Tom Woods or High Angle is your best bet for sure buddy.
Rusty78364
Looks like im going the tom woods route, just gonna have to tale the measurements for fully conpressed fully extended and at ride height on top of flange measure ments then ill be giving then a call!
jangelfire
Im waiting veryyyyyy patiently for a local giy to build my lines. Hes not been on point to say the least. The estimates i got from him, after bringing him a buncha parts is sad to say the least.i coulda had woods lines by now and cheapet! Do it bro!
Rusty78364
Hey guys, so im trying to figure out a shackle set up and i dont know if i want to move my spring hanger forward and run longer shackles or if i want to leave the hanger where it is then run a dual shackle setup. What i would like to know are the pros and cons of running dual shackles.
What i know:
Pros:
More droop
Better flex
Cons:
Tend to unload when side hilling, wouldnt putting a pin in to lock it from unloading resolve this issue?
Rusty78364
Im pretty low only have a 4" lift and if i run dual shackles that are 4" each, at full extension they would theoritically be equivelent to a 7" shackle so the unloading and fliping on your side deal wouldnt be that big of a factor would it? Since a lot of guys are running 6" single shackles? And when they are at full droop they dont flip over...???
LittleSteve
I doubt anyone has the patience to pin a shackle between obstacles. Gotta be at some sorta angle to unload and fall over!
What length springs you runnin?
1985CRAWLER
ive been running dual shackle setup with my rear 63s for awhile now, wheeling and dd use, never had them unload on a sidehill or on the street, i keep the bolts tight.evens at full droop ive never had them invert backwards.
ruffstuff 6" shackles and stock chevy 4x4 shackle bolted together.
MRHilux87
I wouldn't recommend that much shackle... I have dual shackles, and they only have unloaded funny when going fast on fire roads.  I use dual shackles to stay lowww....  I use the ruffstuff chevy kit.  Works great.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
Rusty78364
Quote from: 1985CRAWLER on February 28, 2015, 05:27:08 PM
Any way you could post a picture of what you are running? 👍😊
Rusty78364
Quote from: MRHilux87 on February 28, 2015, 11:30:17 PM
Same thing, anyway you could post a picture of what you are running? 😊
1985CRAWLER
MRHilux87
it does pretty well...  i don't have any close up pictures.  I bought the ruffstuff 63 kit.
2013 Ninja 1000
SOLD:
Rusty78364
Hey guys, havent posted for a while at a stand still again with my truck. Been super busy with work but anyone know of nice decently priced tube bumpers out there for sale? Let me know!
SqWADoosh
Quote from: Rusty78364 on May 04, 2015, 07:33:16 PM
I will keep an eye out for you.
