Author Topic: Load sensing proportioning valve  (Read 10148 times)
dt
  • Turtle Points: -107
  • Member since Oct '07
« on: Jan 18, 2015, 12:34:33 PM »
Whats the "best" way to deal with the (LSPV)  proportioning valve,whats the best way to bleed them? and Whats the best way to eliminate them? or lenghthen the rod that goes to it or....what??
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • USMC NO BETTER FRIEND NO WORSE ENEMY
Re: Load sensing proportioning valve
« Reply #1 on: Jan 18, 2015, 01:57:29 PM »
 :dunno: zip tie . . . look to the left of the sway bar lol
except BACON
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #2 on: Jan 18, 2015, 02:37:04 PM »
above the tire........
What did you steal the rear sway bar from?
*** YELLER ***
  • Male Posts: 4,686
« Reply #3 on: Jan 18, 2015, 03:32:43 PM »
yup above the tire
pm sent
except BACON
Willard
  • Turtle Points: 1608
  • Male Posts: 627
  • Member since Dec '14
« Reply #4 on: Jan 18, 2015, 04:44:22 PM »
Remove it and remove the line that ties into the front line and plug it. Then install a wilwood self adjusting porportioning valve. This is what i did and it also allows tuning of your brakes. Works great.
FJ40NUT
  • Toyotas are the coolest
« Reply #5 on: Jan 19, 2015, 10:03:49 AM »
Why remove it?  I dropped one with a homemade bracket on an Land Cruiser roughly by the same amount as my lift and all is well.
Did Toyota accept a government bail out?
Willard
  • Male Posts: 627
« Reply #6 on: Jan 19, 2015, 12:24:36 PM »
90% of the time they dont work correctly. I have seen them fail. I did it to be able to tune my breaks individaully. It made a big difference, but i also have full widths and a gm 1ton master cylinder so little different.
Willard
  • Male Posts: 627
« Reply #7 on: Jan 19, 2015, 12:27:44 PM »
And i think the guy who wrote the topic is looking for a remedy. If you look at the picture the rod is cut. So its useless anyways  :hammerhead: There a pain in the ass to bleed even with a vacuum pump.
*** YELLER ***
  • Male Posts: 4,686
« Reply #8 on: Jan 19, 2015, 03:38:42 PM »
that was the 2nd post and not the OP of this thread thats mine :cheese: it was an example of what he could do
except BACON
Willard
  • Male Posts: 627
« Reply #9 on: Jan 19, 2015, 04:04:12 PM »
Ooops....well anyways. Getting rid of that thing is a good remedy. Question answered.
dt [OP]
« Reply #10 on: Jan 19, 2015, 07:40:11 PM »
My truck is bareley lifted,and my lspv leaks,and I just wanted to see what all my options are ,mines been leaking for a couple of years so Im gonna do something,just want to get fully informed.thought about the wilwood ,and might go that direction,but I like the idea of just moving the bracket or lengthening the rod also,more pictures please
« Last Edit: Jan 20, 2015, 09:02:59 PM by dt »
dt [OP]
« Reply #11 on: Jan 20, 2015, 09:09:35 PM »
I was looking at some old posts...and one guy had his wilwood adjuster installed in his shift tunnle,by his twin sticks,so he could adjust his brakes while mobil
*** YELLER ***
  • Male Posts: 4,686
except BACON
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #13 on: Jan 21, 2015, 09:15:06 AM »
When you take the LSPV valve off the feed line from the MC is long enough to go to the bracket on the gas tank. Carefully bend it over to hook it there to hook the soft line to.
I just plugged the "T" in the PS wheel well where the return line to the front brakes. Some people have changed the fitting from a "T" to an "L" fitting.
When I first did it I mounted the adjustable proportioning valve back there. After about a year I went to change the adjustment on it and it was frozen solid, So I remounted it under the hood off the MC.
boobap
  • Male Posts: 87
  • Member since Mar '08
« Reply #14 on: Jan 21, 2015, 12:28:15 PM »
I did this also. I accidently bought a SAE adjustable valve from Summit, so I had to get special lines made. After that, LSPV is GONE and no more leaks! Just remember to test and see if rear brakes lock first. Could be a bad day for you if they do! Especially in a turn...
An eye for an eye makes the world blind.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #15 on: Jan 26, 2015, 03:21:30 PM »
I found a location on my 4Runner to bolt the rod to the bottom of the cab thus eliminating it all together. I made a thread on it on here somewhere a while back.
Willard
  • Male Posts: 627
« Reply #16 on: Jan 26, 2015, 04:19:01 PM »
I understand the rigging the rod sonics out of the way, but for a permanent fix it really makes no sense. You really never know how well its working because it's not functional. The wildwood is 50 smakers and all you do is delete the line to front with a plug and cut and re flare the rear line to accept the proportioning  valve. And it really works great. I like that in cab set up pretty slick there :biggthumpup:
Last post Mar 01, 2003, 01:11:27 PM
by gnob
Last post Jul 27, 2010, 08:49:21 PM
by SloCrawler
Last post Dec 26, 2006, 06:54:04 PM
by _HOIST_
Last post Feb 13, 2013, 12:35:55 PM
by 85yotapolo
Last post Nov 25, 2011, 12:24:44 AM
by Rocksurfer
