Author Topic: 2wd Toyota Pickup W55 Transmission $210 shipped  (Read 7144 times)
Erick561
  • Trade Count: (+12)
  • Turtle Points: -79
  • Male Posts: 909
  • Member since May '14
  • Toyota Truck Dismantlation
    • Toyota Truck Dismantlation 75-95 Toyota Pickup 4Runner Parts
« on: Oct 04, 2014, 06:45:12 AM »
Up for sale is this 130,000 mile 1990 2wd Toyota Pickup Truck Transmission which comes as pictured with the base plate, clutch fork, throwout bearing, throwout bearing housing, throwout bearing clip, external slave cylinder, bellhousing.  I can remove the bellhousing and lower the price $25 just let me know.  Thanks
$210 shipped through Paypal.  I've sold 6 2wd transmissions so far and This will be the 3rd 2wd transmission that I sell online and ship (I also have this advertised locally for $170)
Thanks
Erick561 [OP]
  • Male Posts: 909
bump
Erick561 [OP]
  • Male Posts: 909
still available
Erick561 [OP]
  • Male Posts: 909
a couple locals were beating around the bush
still available
twistedtoy92
  • Trade Count: (0)
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
I know this is an old thread but do you still have any 2wd w55-59 transmissions?
Erick561 [OP]
  • Male Posts: 909
Bump got a w55 for sale no bellhousing comes eith forward shift lever 1993 2wd pickup 80,000 $250 cash will ship
Erick561 [OP]
  • Male Posts: 909
I'll let you guys know when I have another 2wd transmission for sale.
joeyg
  • Trade Count: (0)
  • Member since Oct '16
I"M CURRENTLY LOOKING FOR a W55 2wd transmission that will match up to a 22r in a truck.   Does anyone know if I can use a w-58 without much of a problem?  I don't believe I can since mine is setup with a 22r in a truck and the w-58 were matched to diffrent engines in cars.  Right?
Erick561 [OP]
  • Male Posts: 909
Usually the w58 is more expensive. Don't buy it with the w58 bellhousing because the w58 bellhousing has a different bolt pattern. You need to put a w55 w56 g52 g54 bell housing on it to make it bolt to your 22r engine
joeyg
  • Trade Count: (0)
Thank you Erick.  But even with the correct bellhousing (which I have and can switch out), the shifter isn't going to line up with the hole, right?  Because the 22r in my case is truck based and the w58 is car based.  I heard it will be off up to a few inches.   Can you verify or dispute that?
Erick561 [OP]
  • Male Posts: 909
There are w58 top shift and forward shift as well so i am not sure which model you source is.  It could have a mechanical speedo input or an electronic sensor
Mudder
  • Trade Count: (+1)
  • Turtle Points: 3487
  • Member since May '15
Top shift and forward shift are style of T-cases attached to transmissions. As W58's they only came as top shift, but that wouldn't matter for a 2wd transmission.
joeyg
  • Trade Count: (0)
So both of you guys are fairly certain that a W58 will match up to my 22r  2wd as long as it has the correct bell housing or I have one from the original transmission (which I do).  I don't know which 4 speed it is though, L40/42 or W40/42.  The vehicle no longer has a VIN plate.
thank you.
Erick561 [OP]
  • Male Posts: 909
The earlier 4  speeds  were  shorter so the driveshaft is longer
thank you.
Nathaniel85
  • Trade Count: (0)
  • Turtle Points: 43
  • Member since Feb '17
Would you happen to know if a W55 will work in a rig that originally had a W52?
'85 2WD Toyota Pickup
Bottom-end: Pre-long block 22R with LCEngineering internals.
Top-end: 20R head with 22R valves - dual springs, LCE Pro Turbo Camshaft (456 lift, 270 in - 276 out), mild port work.
32/36 Weber carb in, and custom built headers out.
In process of throwing a KO3 turbo out of an Audi A4 into it. Just need exhaust manifold and plumbing done.
Also, have an '87 Corolla FX-16 in the process of rebuilding. Started knocking on me 2 weeks after purchase, with supposed rebuild 20k ago.
It's a sick little sleeper though.
Erick561 [OP]
  • Male Posts: 909
the length of the transmissions is a little different so it will need a matching driveshaft
Nathaniel85
  • Trade Count: (0)
  • Turtle Points: 43
Hey, thanks for the reply man. I've been trying to find a transmission to replace my dead W52 - found a guy with a W55 but that looks like it wont work since they're different lengths, and he's keeping his drive-line.
Do you know this from personal experience, or is there a tech writeup somewhere on the lengths and/ or spline differences etc. that a person could work out whether a trans. would be swappable? Been searching all over a bunch of forums and there just doesn't seem to be much info on the 2WD transmissions where there is for the 4WD models. Would love to know what transmissions will and wont work in my rig.
Erick561 [OP]
  • Male Posts: 909
toyotaminis.com has good info on 2wd drivetrain lengths and driveshaft lengths
Last post Aug 29, 2011, 11:13:02 AM
by toomanytoyzz
Last post Nov 14, 2012, 09:56:43 AM
by Hamsters83
Last post Jan 21, 2013, 01:06:08 PM
by zembalayan
Last post Sep 15, 2014, 07:40:01 AM
by Erick561
Last post Oct 03, 2016, 09:48:36 AM
by Erick561
