0 Members and 9 Guests are viewing this topic.
I"M CURRENTLY LOOKING FOR a W55 2wd transmission that will match up to a 22r in a truck. Does anyone know if I can use a w-58 without much of a problem? I don't believe I can since mine is setup with a 22r in a truck and the w-58 were matched to diffrent engines in cars. Right?
Thank you Erick. But even with the correct bellhousing (which I have and can switch out), the shifter isn't going to line up with the hole, right? Because the 22r in my case is truck based and the w58 is car based. I heard it will be off up to a few inches. Can you verify or dispute that?
There are w58 top shift and forward shift as well so i am not sure which model you source is. It could have a mechanical speedo input or an electronic sensor
So both of you guys are fairly certain that a W58 will match up to my 22r 2wd as long as it has the correct bell housing or I have one from the original transmission (which I do). I don't know which 4 speed it is though, L40/42 or W40/42. The vehicle no longer has a VIN plate.thank you.
Would you happen to know if a W55 will work in a rig that originally had a W52?
Hey, thanks for the reply man. I've been trying to find a transmission to replace my dead W52 - found a guy with a W55 but that looks like it wont work since they're different lengths, and he's keeping his drive-line.Do you know this from personal experience, or is there a tech writeup somewhere on the lengths and/ or spline differences etc. that a person could work out whether a trans. would be swappable? Been searching all over a bunch of forums and there just doesn't seem to be much info on the 2WD transmissions where there is for the 4WD models. Would love to know what transmissions will and wont work in my rig.
Started by toomanytoyzz Parts For Sale
Started by yota18 Parts For Sale
Started by rocksdoesyota Project Research and Build-Ups
Started by Erick561 Parts For Sale
