Author Topic: Duals 4.7 rear install help  (Read 1178 times)
Reeses81
  • Turtle Points: 273
  • Member since Jan '14
« on: Mar 15, 2014, 06:28:16 PM »
I have a 91 runner 3.0 5 speed. I picked up a set of duals, not sure what they came out of. The input shaft is a 21 will this bolt right up after acquiring an adapter plate? Or will I have to get a 23 spline input? Any help would be greatly appreciated. Thanks
fj-rankenstein
  • Turtle Points: -1
  • Male Posts: 583
  • Member since Jan '05
  • my yard looks like toyota circa 1980
Re: Duals 4.7 rear install help
« Reply #1 on: Mar 15, 2014, 11:06:25 PM »
you will need to change your input to a 23 spline....  i would be interested to know what your rear tcase has for an input...
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
Reeses81 [OP]
« Reply #2 on: Mar 16, 2014, 07:04:28 AM »
I did some research I have a 1988-1991 EFI R150F 5sp 23 spline 3.83 V6 3.0L Chain driven Forward Shift . The duals I bought came out of a pick up with 22re(21 spline) I will need and just ordered the 23 full spline input from marlin. The rear case does have a 23 spline it's a 4.7 anything else I'm missing? Thanks again
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #3 on: Mar 16, 2014, 09:06:22 AM »
Just get the 3.0 adapter kit, and 23 spline input and your good to go!
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
« Reply #4 on: Mar 16, 2014, 01:05:14 PM »
yup goldrush is correct!. considered also getting a dual cross member as well to hold up those cases and protect them.
 find a drive shaft with a cv to use for the rear when u shorten it, will help with the vibes.
Last post Oct 11, 2005, 03:54:31 PM
by dj
Last post Mar 26, 2006, 03:21:58 PM
by snowshoebrue
Last post Feb 21, 2008, 03:11:33 PM
by iNfErNaL
Last post Jul 23, 2009, 04:56:13 AM
by V-Man
Last post Apr 07, 2020, 08:25:14 AM
by jperalta8
