Project: Reed's Ride '81 longbed~3RZ swap~
Started by HogCanyonHopper, January 17, 2014, 06:26:47 PM
HogCanyonHopper
couple pics of the heim steering set-up  :driving: :
ryantowry_81
those heims are sure BLING!
good you got the weld in bungs with the nut shape on the end. i built the steering on my one ton swap in the past with bungs that didnt have those and adjusting the steering only with a pipe wrench chewed up the tie rob and drag link. much cleaner this way.
word of wisdom: dont burn your first pass too hot when welding in the bungs and only do it with the heim threaded in with lots of antisieze. i killed a set of bung threads by going too hot on the root pass when i first did them and the TRE would not thread in after. sucked to have to cut them off and redo the whole link!
HogCanyonHopper
HogCanyonHopper
yeah, the heims are not setup correct in that pic. they will be flipped
HogCanyonHopper
Quote from: HogCanyonHopper on March 28, 2014, 10:33:01 AM
This is how they will be installed:
Crunchy Taco
What co. Did you get the heims and spacers through? Just curious, I like the shorter spacers for the tierod so there's not as much movement. I need shorter spacers on my tierod.
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
HogCanyonHopper
ryantowry_81
can you ex plain to us Heim newbs why you swapped the misalignment spacers? i would think the wider based one would be better on the pittman arm side to help keep the bolt in shear and not bending.
HogCanyonHopper
I called ruffstuff. they said to use the safety misalignment spacer against the bolt in case of heim failure. the other misalignment spacer, which is not safety, goes against the arm. its all just to keep the heims captive in the event of failure. the safety washers are used on the tied rod with the 5/8 heims to allow a little wiggle room. pretty simple really
megaphoneman
Quote from: HogCanyonHopper on March 28, 2014, 12:08:06 PM
Man you explained that so well!!! :-) and that all looks perfect!!
Blaaaaaahhhhhhhhpppppppp
ryantowry_81
That makes sense.  thanks for the info.
now more pictures of progress! chop chop!!!  hahaha
HogCanyonHopper
Got the front crank bolt off. new seal:
new rear main seal:
rear sump strainer:
plenty of ultra grey:
pan installed:
need to find something to plug the front dipstick hole. pretty sure the last kit I got had a plug included, from LC iirc, but this Chilkat kit doesn't have one. dern it
Chilkat motor mounts
ryantowry_81
HogCanyonHopper
Tungsten Slayer
Tungsten Slayer
I've seen several folks either tack or bolt that dipstick tube to the conversion mounts to hold it in place.  Might be easier before the motor goes in.
HogCanyonHopper
Quote from: Tungsten Slayer on March 29, 2014, 11:10:56 AM
Thanks for the tip
HogCanyonHopper
Working on the front axle today. I am using the TG Rock Ring kit. I like this kit because it eliminates the felt, uses a thicker/tougher rubber ring and the retaining rings are thicker than stock. Nice having new hardware too, which the kit comes with.
megaphoneman
Can you come do mine when ur done...
Dingman.
Joe i think you have the knuckle the wrong side in that last picture.
1985CRAWLER
lovin this build. keep it coming!
and dingy has a point about the knuckle..i think its backwards!lol
HogCanyonHopper
Quote from: Dingman. on April 02, 2014, 08:58:42 PM
I was waiting for someone to catch that haha.
FROR Tacoma brake kit requires that you swap the knuckles from side to side. Picking up some wheel bearings today and hopefully have the front axle together.
Here is one of the motor mounts installed:
Put a later style flange on the front:
New clutch kit:
ryantowry_81
looks like it is getting there!
what rotors and calipers are you using? i was told that kit can handle all the way up to the tundra calipers and rotors, good sized beef!
Dingman.
Tungsten Slayer
I just went back and read about the lack of a plug for the old dipstick hole.. were you able to reuse the one pushed out of the new dipstick location?  I will consider adding this to the kit if not, but I have re-used the ones supplied by Toyota in the new dipstick location.
HogCanyonHopper
Quote from: ryantowry_81 on April 03, 2014, 09:02:55 AM
I'm using calipers and rotors off of the donor truck. 99 Tacoma
Quote from: Tungsten Slayer on April 03, 2014, 09:57:27 AM
I didn't think to save the plug when I knocked it out and have no idea where it is lol!! The plug that comes with the LC kit is like a tiny freeze plug. No biggie. I have the old dipstick in there temporarily :hammerhead:
1985CRAWLER
im so glad to see the toyota oil filter on that motor, its all i use, i have like 5 of them in my garage! smart man
HogCanyonHopper
Quote from: 1985CRAWLER on April 03, 2014, 06:00:41 PM
I don't always get those. Sometimes I grab Wix or Napa Gold (which is made by Wix), but I usually try to grab the Toyota ones.
Heres some front axle progress. One side is done, except for pulling the wheel studs through. Other side should be finished by tomorrow.
Old race on top of new race, small rim to small rim:
Tap Tap Tap!!!
installed
Ifs hub with FROR Tacoma brake kit bracket:
What it looks like with the Tacoma rotor and caliper:
1985CRAWLER
hey joe will the tacoma brakes clear 15s?
i have the ifs hubs with skys hub kit, ive been thinking about the tacoma brake conversion for awhile now.
