Nations 3RZ-FE Turbo Swap/Build Thread MegaSquirt Install
Started by Nation, December 26, 2013, 02:56:37 PM
Nation
Quote from: 1985CRAWLER on December 31, 2013, 02:41:50 PM
love the tools scattered all over the floor. thats how my stuff always ends up. if u were near id be giving ya some help with that so i could learn, one day ill swap a 3rz.
follow chims advice. his swap was clean :thumbs:
Thanks 85. Id sure love the help. I have since looked into my fuel line situation and got the clutch line off of the fire wall. I think I am going to find the doner trucks fuel line. UNLESS,  someone else has an idea or a how to.. :driving:
Nation
UPDATE. I went out and bought everything I thought I had to complete the swap. Ordered the Chilkat oil pan today. Here are some pics showing my progress for today. I got the motor in. :flamer:
A tip when doing this swap: REMOVE THE CLUTCH! this will make everything much easier. also, the bracket that is meant to hold the rubber clutch line to the firewall kind of gets in the way as well. I did NOT hack it off, but it wouldn't e a bad idea to do so.
Nation
forgot. I installed the dual cases to the trans today as well.
Those are some sexy parts :boobs:
Nation
 :thumbs: just waiting for the chilkat oil pan...then progress will continue. I hope to receive it in the mail today or tomorrow. Once I do the oil pan conversion I will be installing the rest of the drive train. I am going to compare the clutches and see what to do there. WHAT TO DO IN REGARDS TO THE CLUTCH?  just use the clutch disc from my 22r and the pressure plate from the 3rz? or will the flywheel from the 22r bolt up to the 3RZ?  :flamer:
Nation
Quote from: HDcruiser on January 03, 2014, 09:26:09 AM
Ya that's my dilemma with the 4.3. I have also read that you have to run a cowl hood to clear the air cleaner.. I'm not diggin the idea of that. I was thinking it would be around 2500 for the 3RZ. that might be the route ill go.
Yeah. I was thinking thats an accurate number $2500...assuming youve purchased a brand new clutch.etc...With everything i have now, motor mounts, oil pan, harnesss' all harnesses, engine, bellhousing, gas tank, ecu, and a few opther things like, oil filter, oil, valve cover gasket and paint...im at $2,000....
TheChewMaster
Keep it going. This will prob be an avenue ill go down in the future. Big mike has pretty much convinced me. 2500 ain't too bad, better than building up a 22r(e) series motor for sure
Nation
Quote from: TheChewMaster on January 03, 2014, 04:41:37 PM
I agree 100%. The motor will be running by sunday at the latest :usa: and thank you for the inspiration.
Quote from: Nation on January 03, 2014, 04:45:54 PM
Famous last words! :ha_ha:
But seriously I hope everything goes well :driving:
toyodaaddict
Looking good! :smokin: all these 3rz swaps are driving me mad. i dont know how you guys get the wiring figured out. im about wast $2500+ to replace my 22re. it makes me sick but when i start reading up on wiring a 3rz i just get lost. ill be keeping an eye on this.
dropzone
81 Toyota Trekker 221:1
Nation
Quote from: BigMike on January 03, 2014, 05:18:25 PM
So very true.
Nation
So, after much struggle and some extensive rigging....I finally got the trans and dual T's up into position. I am having a hard time getting the tcase mount and x member to line up to fasten down, but I should work that out today. ALSO, I used the stock 22r fan clutch and fan. I did this by drilling out the holes a bit on the 22R  fan clutch to fit onto the 3RZ water pump studs. went right on. well see if it is enough cooling...PICS TO COME later on today. I just need to get some more done. Time is a ticking. :turtle3:
HogCanyonHopper
TheChewMaster
Nation
and my garage door just fell onm y truck. someone backed into it last night I guesss.... I opened it up and then it went boom bang drop. minimul damage but still wtf!!!
HDcruiser
That blows a$$..... just another expense you didnt need.
Nation
#47
Yeah. All of my tools are open to the public all day along with all of my other goodies. .  Lame. Oh well......
Nation
OK. I got the trans bolted up and the starter installed. I had to elongate the x member t-case mount holes in order to have been able to install the T case mount. Otherwise the t-case mount did not line up at all. Then I ran into another issue. In order to bolt the driver side of the t case mount to the x member safely. I had to have my friend pull on the motor with all of his might to the d side so the t-case mount would sit flush on the x member in order to get it fastened securely.
Also my garage door fell on my truck. I have some good pics of it on my cell..
The wiring is coming along smoothly though. ONE WIRE AT A TIME.
Nation
The yellow attempt of an arrow is pointing to a leak Ill need to fix where the rear -case meets the adapter. JUST KEEP SWIMMING! :cheese:
Nation
Quote from: HDcruiser on January 06, 2014, 05:58:36 PM
I got the garage door down and nailed it to the frame with the help of a buddy. so now its closed. with my truck stuck inside  :hammerhead:
HogCanyonHopper
you got plans to get a dual case xmember? projects looking good  :thumbs:
Nation
I doooo! I am going to get the one that connect to the frame wih the u bolts..make life easier. And thanks hog :)
Nation
Quote from: Nation on December 31, 2013, 02:56:20 PM
Not sure yet...but i may have to lay a new line. I am going drom a 22r. I did do a little research before starting. But a lot of what i needed an answer dor i could not find. So i hope i can give the advice and info that i havent seen on others write ups.
This saturday i am going to pick up an EFI gas tank off of an 88 runner with pump and all. I will be using the stock 22re fuel pump and routing my own plumbing.                   (fuel line)..
4runner
your trucks lookin good...sorry to hear about all the delays tho
built not bought 89 4runner
vortec v8, r151, dual cases
4link 1/4 elliptical
Nation
Quote from: 4runner on January 07, 2014, 05:53:16 PM
Hey thanks man!  :beerchug:  its ok. Life happens. Timing sucks though.
Nation
I have received my chilkat oil pan. Its perty. Pics to follow with install
79toy20r
Nation
Quote from: toyodaaddict on January 03, 2014, 06:37:29 PM
My motor is the "COP" coil on plug design. so it is differernt then wiring up a dizzyd motor. When i finish the wiring I will at least show which wires you need/color of wire and what each terminal plugs into and what splices where to retain the factory gauge cluster and what not.
1985CRAWLER
 :sleeping:
what happend?
more of this swap please....:popcorn:
