Author Topic: 1983 DIESEL 5spd Long Bed  (Read 3438 times)
kzunell
  • Turtle Points: -1
  • Member since Jul '13
« on: Jul 20, 2013, 02:08:08 PM »
  So I have been looking at this 83 2WD Toyota long bed P/U that has been parked in a yard in the dessert by my friends new house. I finally run into the owner and ask him about the truck and he says it is a Diesel??? and he hasn't driven it since he moved out of the house 4 years ago.  I ask him if he wants to sell it and I look at it. The body is perfectly straight with no rust anywhere. The windshield has a small crack in it. I look under the hood and it is a Diesel (non turbo) and the heater core has been bypassed. The battery trays are toast and the hose between the air filter and intake is cracked. Someone had broken into the truck by breaking the latch on the rear sliding window and had broken the ignition.  The only body damage I found was 2 bullet holes in the passenger side door (to me this gives the truck character haha) that went thru the outer skin but didn't go all the way thru the interior skin. I am thinking they were 38 hollow points.  Well we settled on a price of $450 and I towed it back to my friends house (about 1/4 mile away on a dirt road).  The tires were still holding air. The parking brake works fine.
   I need to drain and clean the fuel system and drain and purge the brake system and flush radiator and change oil and fix the ignition switch and replace the two batteries and battery trays. and it should be good to test drive.  Then I have to decide what to do with it. From what I have read on these trucks they get close to 40mpg on the highway but do not have much power. 63hp and 93ft/lbs of torque. I am thinking I might add a turbo and modify the fuel injection system (mechanical system), or replace it with a more modern diesel engine if anyone has any ideas or recomendations?
  Thanks,  Kelly
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
Re: 1983 DIESEL 5spd Long Bed
« Reply #1 on: Jul 20, 2013, 04:32:29 PM »
Let's see it.  Pics please.  Especially that motor.
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #2 on: Jul 20, 2013, 05:36:07 PM »
He needs alot more posts before he can post pictures.  Alot of the Cali guys love the diesel toys, for the fact that you can put in any motor you want and not worry about smogging.
kzunell [OP]
  • Turtle Points: -1
« Reply #3 on: Jul 21, 2013, 07:54:12 AM »
  How many posts do I need to post pics?
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #5 on: Jul 21, 2013, 12:32:53 PM »
Fix it up and tune it well and enjoy a reliable little fuel saver
njtrekker
  • Turtle Points: 350
  • Male Posts: 18
  • Member since Oct '11
« Reply #6 on: Jul 21, 2013, 07:32:36 PM »
You should also replace timing belt,idler pulley and tensioner. to be safe. the pulleys tend to go bad and the timing belt will wander off and brake. This is a noninterference motor. you may want to change water pump why you got it all apart also.
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,728
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #7 on: Jul 21, 2013, 09:59:45 PM »
You would spend a fortune on a newer deisel motor swap. I probably spent $7000 on my 1KZ-te swap. If it will fire up, I would say keep it the way it is. The original diesels are rare.
kzunell [OP]
  • Turtle Points: -1
« Reply #8 on: Jul 22, 2013, 07:48:50 PM »
  Well put 2 batteries in the truck and cleaned the battery terminals. Pulled the steering colum apart and pulled the ignition switch apart. Turned the switch and it cranked over. Checked the fuel filter and water separator both had fuel cranked it over again and it fired right up. Checked everything and a few lights don't work and the engine oil light doesn't work. Clutch is fine gears work. Brakes master cylinder was empty so will have to bleed the system.  Ohh and radio works but speakers are blown. Not sure if the cassette player works.
Cheesemaker
  • Male Posts: 4,525
« Reply #9 on: Jul 23, 2013, 07:30:34 AM »
:thumbs:
kzunell [OP]
  • Turtle Points: -1
« Reply #10 on: Jul 24, 2013, 06:38:38 AM »
Is there a tach on some diesel pickups? Is there a different gauge cluster? I can use? I only have a speedometer and a fuel gauge and temp gauge then the idiot lights for the rest.. It does have a glow plug light and oil light and amp light etc.. what are the after market gauge options available specifically for Toyota p/u's?
  thanks
helipilot77
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
« Reply #11 on: Jul 24, 2013, 05:32:05 PM »
I'm pretty sure that all diesel trucks came without the tach. It would be challenging to add one on a manual injection pump model like yours. Although I read something once about being able to get a tach signal off the alternator.
Last post Aug 02, 2006, 01:08:51 PM
by *FFC*
Last post Mar 29, 2007, 06:39:41 PM
by crazymoritz97
Last post Feb 18, 2010, 10:41:59 AM
by vetta
Last post Jul 06, 2014, 04:09:26 PM
by loctupdave
Last post Sep 06, 2016, 02:35:38 PM
by thebigblkbuss
