Author Topic: Pilot bearing removal  (Read 3534 times)
Kyle20r4spd
  • Turtle Points: 3
  • Male Posts: 82
  • Member since Mar '13
  • Gotta Love A Yoter!!!
« on: Jul 01, 2013, 05:44:27 PM »
Quick question, how do i remove the pilot bearing without pulling it apart(prying on it with a screwdriver) this is on a 20r. I am so close to putting in my W56 :booya: Just the clutch and drivelines and it will be ready for install :woohoo:
Just put er' to the wood and it'll make it!!! -Dylan W.
Isn't ketchup technically a tomato smoothie???
Cyberman
  • Member since Dec '07
    • Build Thread
Re: Pilot bearing removal
« Reply #1 on: Jul 01, 2013, 06:21:46 PM »
Typically, you would use a slide hammer to pull a pilot bearing.
Sent from my DROID RAZR using Tapatalk 2
'91 Xtra cab 3.0 SAS, 5.29s, single 4.7 transfer, locked f/r, 35s
My Frame-up Rebuild Thread
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
« Reply #3 on: Jul 01, 2013, 06:33:28 PM »
Fill the inside with grease. Then use a round object the size of the i.d. of the bearing (a 3/8" extension works) and hit it with a hammer. Fill with more grease and do it again. Should get it out. There's also tons of write ups all over the internets.
Kyle20r4spd [OP]
  • Turtle Points: 3
  • Male Posts: 82
« Reply #4 on: Jul 01, 2013, 07:43:45 PM »
So the pressure of the grease actually pushes the bearing out from behind, interesting Im going to have to try that
BadnewsBob
  • Turtle Points: 9
  • Male Posts: 350
  • Member since Sep '11
« Reply #5 on: Jul 01, 2013, 08:37:40 PM »
I've removed a bunch this way...the tighter your punch is to the hole the better it works.
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
Kyle20r4spd [OP]
  • Turtle Points: 3
  • Male Posts: 82
« Reply #6 on: Jul 01, 2013, 08:41:40 PM »
Nice, I will try it tonight while it is still cool out.
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #7 on: Jul 01, 2013, 08:47:12 PM »
Liquids cannot be compressed (on a macro level) so what you get is a http://en.wikipedia.org/wiki/Hydraulic_press
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #8 on: Jul 01, 2013, 11:39:34 PM »
Interesting.   I'll keep this technique in mind.
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #9 on: Jul 02, 2013, 07:20:39 AM »
I use one of my 1/4" drive sockets with an extension. I don't remember what size but, it fits perfect and works on the first hit.
88 Pickup SAS'd, 3.4 V6, R151F Hybrid, Dual Ultimate, Triple sticks, 35's, 5.29's, HP front, V6 rear, Aussies, 63" Chevs, Anti Wrap Bar, Warn 8274 on Home Built Bumper
4WU linked 86 Xtra Cab build in progress
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #10 on: Jul 02, 2013, 08:31:30 AM »
White bread works great too and no mess.
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,144
  • Member since Sep '08
« Reply #11 on: Jul 02, 2013, 09:38:54 AM »
grease is messy. I use wet toilet paper and a bolt i ground down to a perfect fit for the center of the bearing. it takes about 10 min of pakin and poundin but its never failed to work.
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #12 on: Jul 02, 2013, 09:40:08 AM »
I always soak strips of newspaper in water, i tried grease but didnt have any luck.
sabatoa1
  • Male Posts: 396
  • Member since Jan '10
« Reply #13 on: Jul 02, 2013, 10:05:19 AM »
Packing bread is the best way to do it. Get a bolt the same dia. as the hole and keep pounding the bread in until it pops out then you pop the bread easily out in one peice no mess.
1984 4runner buggy 22r on pane, duals, hydro assist, spool front, spool rear, 37x13x16 Creepy Crawlers.
http://board.marlincrawler.com/index.php?topic=89989.0
Kyle20r4spd [OP]
  • Turtle Points: 3
  • Male Posts: 82
« Reply #14 on: Jul 03, 2013, 07:11:19 AM »
Already got it out the grease worked great :thumbs: Just used a ground bolt and packed lots of grease then a hit and it popped right out. Thanks guys. By the way 90Suprunner how does the 7MGE do in a runner? How hard was it to swap it in?
sabatoa1
  • Male Posts: 396
« Reply #15 on: Jul 03, 2013, 12:24:46 PM »
It was very easy to swap in and it runs great and gets great gas mileage. Practically a bolt in after finding all the parts
Kyle20r4spd [OP]
  • Turtle Points: 3
  • Male Posts: 82
« Reply #16 on: Jul 03, 2013, 06:24:44 PM »
Nice to know for future reference, possibly...:shhh: nobody needs to know.
2010nctaco
  • Member since Jun '13
« Reply #17 on: Jul 05, 2013, 07:14:17 AM »
X2
zidaro
  • Turtle Points: 480
  • Male Posts: 526
  • Member since Oct '02
  • Mo Chi Chu!
« Reply #18 on: Jul 08, 2013, 09:19:36 PM »
soggy newspaper stuffed then a bolt tapped into hole, over and over.  ~10min. of time, works great
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
andeze
  • Turtle Points: -1
  • Male Posts: 51
  • Member since Jun '11
« Reply #19 on: Jul 08, 2013, 10:12:08 PM »
X2 on the bread, works great, no mess, and is pretty amusing to use bread for auto repair
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #20 on: Jul 09, 2013, 09:35:47 AM »
Bar soap worked for me. And you can clean your hands after too..
Last post Jan 15, 2003, 10:22:11 PM
by mr4x42u
Last post Jun 28, 2006, 07:39:21 PM
by jimbo74
Last post Apr 12, 2009, 02:52:02 AM
by jimbo74
Last post Jun 19, 2010, 12:57:31 AM
by gtoyonrocks
Last post Aug 31, 2012, 08:27:38 AM
by Travis H
