Fill the inside with grease. Then use a round object the size of the i.d. of the bearing (a 3/8" extension works) and hit it with a hammer. Fill with more grease and do it again. Should get it out. There's also tons of write ups all over the internets.
So the pressure of the grease actually pushes the bearing out from behind, interesting Im going to have to try that
Packing bread is the best way to do it. Get a bolt the same dia. as the hole and keep pounding the bread in until it pops out then you pop the bread easily out in one peice no mess.
It was very easy to swap in and it runs great and gets great gas mileage. Practically a bolt in after finding all the parts
I always soak strips of newspaper in water, i tried grease but didnt have any luck.
Started by Huhwhye General 4WD Discussion
Started by Serenity now! Toyota Pickup/4Runner Tech 1979-95
Started by i_luv_my_truck Toyota Pickup/4Runner Tech 1979-95
Started by SamuelEngelking Newbie Questions
Started by Travis H Newbie Questions
