I am new at this. Why HAM over CB? Range?Can you explain the private channel thing? HAM has private channels or just more, so it is less likely to be overheard?And CB doesn't require a license anymore does it?
You could use those Baofeng HTs on MURS freq which arent HAM. Multi-Use Radio Service (MURS) is an unlicensed two-way radio service similar to Citizens Band.1 151.820 MHz 2 151.880 MHz 3 151.940 MHz 4 154.570 MHz 5 154.600 MHz
Still illegal to use Ham Radio type radios on MURS. Don't do it.
No MURS transmitter shall, under any condition of modulation, transmit more than 2 watts transmitter power output.
Actually, you can use almost anything to transmit on these frequencies. The stipulation is about how much power you use to transmit over these frequencies:-http://www.fcc.gov/general/multi-use-radio-service-murs
Started by FZJFillmore New Member Check-In!
Started by KYOTA New Member Check-In!
Started by KSToy New Member Check-In!
Started by firekiller New Member Check-In!
Started by 91Toyota4x4 New Member Check-In!
