Author Topic: Fiverivers Runner, from DD to now  (Read 7069 times)
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
« on: Sep 16, 2012, 08:25:04 PM »
I never really put a thread up on this forum showing my truck and what ive done to it... since ive had some time as of late... I guess i will "show" her off lol
got the 84 after we decided to have another kid.... needed a "family' rig...
so kept it basic at first, fixed the body damage and lifted just a little
Im by definition NOT a body man....  so i was proud i could get the panels in there and make it look decent lol
Those are some huge welds!
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
Re: Fiverivers Runner, from DD to now
« Reply #1 on: Sep 16, 2012, 08:31:50 PM »
along with the lift, had to modifiy my steering.... here is  a modified steering arm and drag link.... worked well even for how redneck it seemed..
j arm ball welded to stock arm...
flipped and welded draglink
Had no problems running this way.
also did IFS hub conversion, with Landcruiser rotors and v6 calipers.
and not really u bolt flip kit but my version
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #2 on: Sep 16, 2012, 08:40:24 PM »
and there is sat...
at this time it had 4.56 gears and open IFS rear and locked front
threw some 33's on er and took some poser shots....
drove it like this for quite a while..... could barely wheel it however because you could not steer it with that damn push pull steering...
couple little details for it while it was a "street" vehicle.... stereo gauges and the switches for the power windows
rear cargo area covers, later wraped in vinyl
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #3 on: Sep 16, 2012, 08:51:37 PM »
after it was decided that it was not going to be the praimary transportation for our children... i started to get a little more serious..
Flipped the weber around for better uphill progression
used throttle cable from Fuel injected truck and made my own bracket... that was about the extent of the modification to flip it
RUF
from
to
still using my push pull i took a spare drag link and shortened it, sleeved it and welded it just like the other one i had done.
also decided to make a square shaft.....
ended up being a disaster as it was loud and heavy.. used wrong material.... oh well live and learn, modified old front driveline to now RUF specs
decent amount of flex, but have since mixed up the pack and it rides and flexed much better
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #4 on: Sep 16, 2012, 09:12:28 PM »
and then.....  i spun two rod bearings trying to show off in a mudpit that a bigger truck couldnt get through...( i made it FYI lol)
so out came my engine...  rebuilt a spare i had in the garage, I put in new stock size pistons, ported the head, installed head studs, and a crawler camshaft, and an adjustable cam gear.. she rips and snorts now...
while i had the engine tore down i ripped the front axle out for an overhaul, she had been leaking at the seals and making a hell of a noise which i came to find out was  two teeth missing from the pinion...  new yukon 5.29 gears and my old lockright went back in rear got a WELDED 5.29 4cylinder third..  along with some home made trussing and a off the shelf diff guard.. and a homebrew 5th stud mod
also decided it was time for crossover steering.... so off came the old box in came the IFS unit...
home built passenger side steering knuckle and all...
new 14" shocks and ford F250 mounts
and installed my winch and cut 33" boggers
rear cage section....
and made my own twin stick shifter (because locker in the front sucks to turn with)
then some testing
it passed
but what was luking in the garage was the next step
« Last Edit: Sep 16, 2012, 09:19:20 PM by bleakhorizon »
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #5 on: Sep 16, 2012, 09:39:01 PM »
i acquired some fairly well used 39.5 iroks for dirt cheap..... then proceded to spend more money on 16" wheels to make em fit then the tires cost..
I had to wait nearly 3 months for the wheels to be custom made to my specs, 16x10 2" backspacing.  (i have no spring to tire interference)
while the waiting was happening the truck went under the knife again.... first a couple small things... tailgate from a ranger
simple hinges as this modification is just cosmetic and to keep my junk in the back
then things got a bit more serious, i received a dual case adapter.... (i know i know, but it was less than cheap from a third hand source and was not even used)
so i proceeded to adapt a forward shift case to top shift, modify my twin stick to shift it, and make my own cross member...
floor blueprints.   lol everytime
....... yet again had to modify my drivelines, this time i took the cv out of the front.... and obviously had to shorten my rear, the two drivelines are now within inches of being the same length
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #6 on: Sep 16, 2012, 09:45:59 PM »
Fast forward almost a year since, have done very little, only been out 3 times since doubler... let me tell you 33's and dual cases makes it slow... it was time for bigger tires
with roughly 4" of lift i was pushing it for clearance with the bigger meats.... took a couple trips around with the sawzall and they fit MUCH better
jump yet again couple months.  fixed my steering/frame clearance problem
also tubbed the firewall because the tires just loved rubbing up against it.
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #7 on: Sep 16, 2012, 09:51:12 PM »
which has brought us to this today....
im assuming that my (as until now) stock slip front driveline was being held in by just a fraction of an inch at full droop, as since ive done the firewall tub it has fallen out three times in the same trip...... this will not do.. and as with the story of this truck, i dive into the scrap bin and come up with a solution.... three drivelines, a bunch of cut off wheels and yet to be welded fully together..
i have my own long spline front driveline, yet to be tested, hopefully will hold together... i hate putting that spare shaft on while on the trail..
Tillamook, OR
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #8 on: Oct 21, 2012, 07:50:26 PM »
well got the driveline in yesterday and got some testing in.... definitely will not be falling out again..
also, spent a good chunk of time working on a new pitman arm..  mine when at full stuff on the drivers side had a nut that would either contact the spring or get stuck beside it... so i made a "low profile" pitman
old.. big nut on the bottom that was hitting.. style
new, floating pin double sheer, not completely finished pitman arm..
Tillamook, OR
Last post Jul 02, 2003, 09:39:46 AM
by BMFN_TOY
Last post Sep 09, 2013, 09:15:57 AM
by H8PVMNT
Last post May 12, 2013, 09:01:47 AM
by robert.levi
Last post Jul 12, 2012, 07:12:49 PM
by fullsizenomore
Last post Dec 25, 2009, 09:45:14 PM
by 86bobbedtoy
