2000 Tacoma getting one tons (new snow wheeling pics)
Started by 86rustbucket, August 09, 2012, 11:53:16 PM
86rustbucket
#30
Quote from: Wainiha on August 30, 2012, 01:30:09 AM
you planning to shave that d70 housing?
I'll probably do a little grinding on it but nothing major, I'll be sick of grinding by the time i grind the calipers down to fit 15 inch wheels.
Here's a little more progress.
front hanger
Rear shackle mount,  just a frame tube cut down to the width of the chevy springs.
Rear spring hanger,  (Ruff stuff frenched chevy hangers)
Wheelbase with front axle moved 6 inches forward from stock position.
yotatough
Nice! I think we're gonna shorten my wheel base the same way! After we see how yours comes out.
86rustbucket
Quote from: yotatough on September 01, 2012, 11:07:54 AM
No, you'll never do it.
I know they are crappy cell phone pics but here's a little more progress.
The drag link is made from. 250 wall tubing and 7/8 heims.  The ifs box is mounted and the steering shaft is done.
HULK
Your 86 was a nice truck bro.  Can't imagine how sweet this one is going to be. :driving:
95toyrunner
Lookin good Brandon. Why did you go with heims instead of TREs for the steering?
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
86rustbucket
Quote from: 95toyrunner on September 11, 2012, 04:23:30 PM
Because heims are shiny. And bitches dig shiny stuff.  :love:
No seriously,  because a buddy got stuck buying 10ft of tubing and gave me his leftover tubing after making his tie rod with 7/8 heims and I liked how his turned out.  Then I found a steering arm on pirate drilled for 3/4 bolt for only $50. So with the ruff stuff heims, arm and 3/4" hardware I was about $150 into my steering setup.
I just went with the stock tie rod with the 1ton tre's. We'll see if it holds up.
yotatough
86rustbucket
Got a set of DIY beadlocks for it.  Looks like I'll be trimming quite a bit of metal.
95toyrunner
Quote from: 86rustbucket on September 23, 2012, 10:11:08 PM
Dude it'll clear. With those flat springs you only got like 1" of up travel anyways :P
86rustbucket
Its getting closer,  I still need to work on drivelines and the bed.
95toyrunner
daniresch
Looks sweet rustbucket. Keep it comin
Sent from the HO KID network using Tapatalk 2
3rCrawler
Sweet ride Brandon !!
Big difference in wheel base mine's @ 120"
And it works pretty good.
Let me know when you guys are doing a taco run...
Pinched Tacoma -3rz,  39.5" Iroks...
axled89
 I no you have some work to still do to it. but you should start thinking of caging that beast.  i like the bead locks looks great nice progress. if you lived closer to me we could do the cage here at my place.
i love oregon wheelin.
TimberlineBryce
See you at the Timberline!
88_Pathy
Just picked up a sweet fj axle for mine, we need to hit the trails for sure. The 4.88 and short 4ds will be a little slow. You will love 3rd gear, cus that is what you will be in all the way up the 4 lane..
86rustbucket
Quote from: THK Matt on September 28, 2012, 05:43:12 AM
Quote from: 3rCrawler on September 28, 2012, 07:51:46 AM
Thanks guys.  I can't to finish this thing.
Justin, were gonna hit coyote on the 20th. If your free give me or Ivan a call.
86rustbucket
Quote from: axled89 on September 28, 2012, 11:28:24 AM
Thanks man!      That would be awesome but I doubt a cage for this thing will be in the budget anytime soon.
I got it drivable and took it up for a little test drive at bald mount
86rustbucket
Then I started working on the double Bob.  Here my lovely assistant Eric shows off the progress after removing 8 inches.
Rocksnail
rig is looking awesome! I might be running coyote or swamp here in a couple weeks. you an ivan will have to join me.
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
86rustbucket
Thanks man!
Let me know when, everything up there will be closing soon.
HULK
Wow bro!  Your truck looks sweet man.  Good job on that thing. :thumbs:
TimberlineBryce
Dingman.
95toyrunner
86rustbucket
I will get some videos up soon I've just been busy.  I still haven't got the bed on it but its getting there.
I did get some bump stops for the front and hope to get those in soon.
We took it up to Red in the snow after that last little storm that hit.
95toyrunner
MAN I want full widths on my taco now :P which reminds me, I still need a price quote on a ruffstuff housing Brandon!
86rustbucket
Quote from: 95toyrunner on November 02, 2012, 11:18:15 AM
I'll text you right now Holden.     Their are a ton of options on those things.
Your Tacoma will be badass with a RS housing!
86rustbucket
Here's a cool pic my buddy sent me from the last trip to bald.
