1985 4runner: traded
Started by yota_krawler, June 09, 2012, 08:01:12 PM
yota_krawler
started tearing down my front axle for rebuild. Picked up 2 4.88 diffs, one open, and one with a lockrite. Lockrite is going up front and i may weld the back im not sure. also got IFS outters but not 100% sure what is needed to use them.
As you saw, I cut the inner fenders out. So I mocked where I want to "try" and put my front axle and how I am going to cut the fenders. I mocked with a 39.5 irok.
enjoy
how are you wanting to do the IFS hubs? there is a few ways to use them, one requires a hub widening kit and the other requires tacoma rotors, and some grinding of the hub bodies and calipers.
ive done the grinding way, twice.
yota_krawler
yota_krawler
what year tacoma rotors?
give me a run down matt lol :gap:
I asked for a 98 v6 4wd front rotor. The ifs hub has to be ground down so the rotor slides on to it from the front. The taco rotors are slightly thicker then an IFS or FJ Rotor, so the calipers need to be unbolted and split in half and the notch in the casting the rotor "goes thru" needs to be opened up a bit so it fits onto the rotor. Also the rotors now need to be mounted on the other side of the knuckle ears. And run a small spacer between the caliper n ears. Its like 1/8" needed i think. I have pics of it installed.
Sent from the HO KID network using Tapatalk 2
yota_krawler
Started tearing apart my axle for rebuild and paint. Then I noticed this... Whats the deal? One IFS or something? The Diameter is the same on both where the bearing seats. Leave it or change one for the other?
Ifs doesnt use that style. Maybe one an early solid style.
yota_krawler
Quote from: THK Matt on January 25, 2013, 07:03:49 PM
just went through your build and didnt see anything.. I got the rotors today
yota_krawler
Quote from: THK Matt on January 27, 2013, 11:43:06 AM
lol Ive never messed with rearing down an ifs... It may just be a different style that came on either an early or later axle?
Quote from: yota_krawler on January 27, 2013, 03:25:01 PM
I never got around to it for this last project i had, it was on the axles i built for my red 2wd ex cab long bed. I have pics on my external HD, ill upload.
Quote from: yota_krawler on January 27, 2013, 03:26:15 PM
Thats what I think yes, someone else confirm?
yota_krawler
ordered up my dual case cross member, one more thing crossed off the list.
tgmaul88
Congrats brotha!!! two little girls, thats awesome.
yota_krawler
86bobbedtoy
congrats on the new baby!
her sister looks as happy as could be!
yota_krawler
got my trans/t cases in finally.... R151 turbo tranny, forward shift crawl box, and 2.28 rear case 23 spline through out. Marlin adapter and a trail gear twin stick. I baught skys skid plate and couldnt be more happy with it.
pics :smokin:
tgmaul88
yota_krawler
this is my second 1st gen runner I missed my old one lol
86bobbedtoy
get er done so we can go wheelin!  hell I think I forgot how to wheel, its been so long
NITE KRAWLERS
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
yota_krawler
Drove it today. Ill take pics soon just need a front drive line now. Super stoked
yota_krawler
So it got pushed outside and hasn't been touched in a few months... Man life is different with two kids lol. Anyway, I got it running and everything but some things aren't working like the radio, blower for a/c [slash] heater, headlights, horn int. light. However, the running lights, blinkers, clock, blacklights on dash do work. Im confused here. Any suggestions
yota_krawler
Shamb
daniresch
Quote from: Shamb on September 07, 2013, 02:19:49 PM
check fuses?
this. the fuses you want to look at are under the steering wheel next to the clutch pedal behind the plastic cover... correct me if i'm wrong.
yota_krawler
checked them 5 times, checked under the hood, EVERY fuse is good. Hense why im lost...
Shamb
Power comes from the main fuse block on the passenger side kick panel through the firewall into the cab. I would pull the fuse block off and look at the wires behind. Make sure there's not corrosion or a power wire came lose.
Dingman.
As far as i know everything worked fine until he did the tube fenders/sr5 gauge cluster swap.
He was thinkin possible ground problem since all te fuses were good.
:dunno:
yota_krawler
ill take some updated pics of how it sits now
