It's nonvisable, and closer to the rear of the case.I'll do some research for ya and see what I can find.
I used one stock mount and one 4xinnovation mount; mounted to a TG crossmember. I did this because I've read about people breaking the mounts when they are two stock mounts. I've also read that with two solid aftermarket mounts the cases can be loud, and both my cases are regarded as the loud cases, pre 84. I have not done too much wheeling yet, but it's not terribly loud, and my engine mounts are stock. From what I've read, chain them. The solid mounts are supposed to be sorta loud/vibrate at high rpms/speedsI put the 4x mount on the rear case
ive got my motor chained and im running leaf spring bushing on a custom xmember
I cant upload pics that's why i haven't updated my build thread The guy before me did it welded the chain to the metal plate that sits over the motor mount and again to the frame
It's a pretty common mod, it's probably in the pirate FAQ
Make shure you leave a little slack for the mount to absorb vibration
All right, jobs are good. Good luck
Started by Jud « 1 2 ... 23 24 » Project Research and Build-Ups
Started by kvn85 « 1 2 » Project Research and Build-Ups
Started by SoUtHTeXaSyOtAs Project Research and Build-Ups
Started by Muddytazz Project Research and Build-Ups
Started by 874runnertoys Project Research and Build-Ups
