83 Slow build
Started by nisota, May 06, 2012, 08:08:25 PM
loctupdave
#150
Chained to fence, you must have a heck of a problem with theft. Truck looks great. You will love that wiring, I did.
A real man builds it... Then his wife points out all that he did wrong.
nisota
Hope this helps hogcanyon, I appreciate you trying to help me out thank you.
Drivers side
Heater wires
Emission control box
Flasher box
Charge Lamp relay
Buzzer?
Passenger side
Column wires
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
nisota
#152
Quote from: loctupdave on March 25, 2013, 05:30:43 AM
Yea there is some Yota stealers around here, They got quite the operation steal the truck part out what they want, Take unwated metal to scrap yard, Bury the rest in a Giant hole out on there property.
Oregon wheelin'
82' 2wd-4wd project
HogCanyonHopper
So, like I said previously, I have the voltage reg, coil/igniter, charcoal canister. Looks like you got just about everything you need as far as the in-cab wiring and components. I'm assuming you have a heater unit??. I can ship the above listed parts to you, but not flat rate box. Charcoal canister is fairly large. PM me your info and we can work out a price for the parts. I can let you know tomorrow how much the shipping will be. You can then install the parts and see what else you need.  :thumbs:
nisota
#154
Is this a charcoal canister? Just trying to indentify parts that I have.  Also what is the black can at the bottom of the picture that fuel line go into?  Also No as of current I do not have a heater/defroster unit I tore it out because it was trashed along with dash & cluster
Oregon wheelin'
82' 2wd-4wd project
HogCanyonHopper
That is your wiper motor. At the bottom is the charcoal canister.
nisota
Oh ok so I dont need another charcoal canister then.
Oregon wheelin'
82' 2wd-4wd project
dropzone
Quote from: nisota on March 27, 2013, 04:00:50 PM
Yep, unfortunately Toyotas get ripped off all the time in the PNW...It really sucks.
I have chained my truck to my flat bed trailer at times too in hopes of slowing people down... :tantrum:
81 Toyota Trekker 221:1
trailcrawler808
nisota
Update: As posted on another thread I found a 86' complete truck with 20r motor and as everybody thought including myself thought it would be hacked up, Well it wasn't it was the most complete and best harness I had seen in awhile and had never been hacked up so I bought it for $30 brought it home and now I'm mostly set up ready to rock n roll just need to figure out a few things (windshield wipers)
So after wiring is done then,
1: mount t-cases
2: brakes
3: fuel
4:finish bed
5:Mount 4 shocks
and other stuff like that, Then shakedown time!
Oregon wheelin'
82' 2wd-4wd project
nisota
Oregon wheelin'
82' 2wd-4wd project
TheChewMaster
Gotta love shake down time, its the light at the end of the tunnel. Ive been on that for a while now, but I think I'm finally confident, other than the slight crack in my block by the starter, all the leaks and bull crap is buttoned up. After my first trial the tranny leaked, and i replaced it, and the steering box too
Looking good buddy  :love:
nisota
Quote from: TheChewMaster on March 29, 2013, 10:47:11 PM
Thanks Heck ya My block has about had it too but I'm ready to find out where I'm at with this build so I'm just going to run it and see what happens.  :driving:
Oregon wheelin'
82' 2wd-4wd project
nisota
#163
Ok So Here is a picture of my 86' ignition harness
And this is my 83' ignition harness
They do not connect together because the 86' is in a 8 slot holder and the 83' is in a 6 slot holder can somebody help me figure the different colors out because they don't match? Thanks  :beer:
Also cut out trans tunnel today for dual cases plan to put them in tomorrow.
And finished cutting old doors to make 1/2 doors now I just need to weld them plan to do it this weekend.
Oregon wheelin'
82' 2wd-4wd project
nisota
Todays Progress: Duals hanging just need to weld up cross member mount.
Started bed bob job Now i need to weld that back together as well.  I have lots of metal to burn soon.
Oregon wheelin'
82' 2wd-4wd project
OldGold3VZE
Looking great. I love the 2wd body.
My 1980 Long Bed build thread
http://board.marlincrawler.com/index.php?topic=84562.0
Truggy build thread
http://board.marlincrawler.com/index.php?topic=89844.0
Rastafari Livity!  Ital = Vital!
nisota
Anybody know anything about the ignition question I posted above? Hot wire ignition or splice 86' harness to old 83' Harness?
Oregon wheelin'
82' 2wd-4wd project
Cheesemaker
I'd splice.  It shouldn't be to hard to compare wire harness diagrams to see what needs to be wired together.
nisota
 ok that's what I'm going to do then thanks cheese  :beer:
Oregon wheelin'
82' 2wd-4wd project
nisota
#169
Put the Drive lines in to see where I was at today and I'm not sure at the moment What do you think? I know the front angle is sharp and needs fixed but the rear seems long and high angle? The rear is a stock short bed drive line the front is a lengthened drive line but not long enough they are both at the end of the splines and need rebuilt Thats why I am looking for suggestions of what you did with your truck.
Oregon wheelin'
82' 2wd-4wd project
TheChewMaster
I used a 84/85 front drive line and had it lengnthed so 3/4 to and inch of slip is showing using the stock splines. For the front used a rear shaft from the same 84/85 and had a 10 inch spline section added, relubed, and shortened so three inches show, no balance on front, and balance on rear
HogCanyonHopper
You'll want to run CV joint in the rear. Or does it already have one? The sharp angle will cause the u-joints to fight each other and give some bad vibes.
OldGold3VZE
I'd be fine with the shafts, it's the short slip in the front that's gonna give you trouble. Build that front shaft out of square receiver tube.
Truggy build thread
nisota
#173
Thanks for the quick responses  :beer:
Quote from: TheChewMaster on April 13, 2013, 10:42:20 PM
you said front 2 times which is your front build drive line & which is the rear?
Quote from: HogCanyonHopper on April 14, 2013, 07:23:13 AM
No but I had planned on putting one in just wanted to make sure my thoughts were on the right page.
Quote from: OldGold3VZE on April 14, 2013, 10:07:32 AM
Thats what I was thinking too.
Oregon wheelin'
82' 2wd-4wd project
NITE KRAWLERS
Wow dude that was a pretty gnarly crash u had man! I was looking thru ur build an I like your seats dude! Also the rear dove looks great! I think every truck should b doved, wish I would of done mine like first thing! An nice shifter knobs on each one, that way u just member which knob is which an shift without even looking!!!!!
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
nisota
Quote from: NITE KRAWLERS on April 14, 2013, 05:53:17 PM
For sure thanks Man Just need a few more things and I should be able to get this truck going I'm getting anxious Ready to see what happens!
Oregon wheelin'
82' 2wd-4wd project
OldGold3VZE
Cage?  Better do it now.
Truggy build thread
nisota
Quote from: OldGold3VZE on April 15, 2013, 09:43:09 AM
I've tossed around the idea of a cage then dismissed it, thought about interior cage then moved on and forgot about it I'm unsure still don't know what to do cause I don't have access to a good tube bender and we used the cheapo harbor freight pipe bender to cage my brothers truck and now it looks super ghetto cause he just kind of slapped it together so unless I get a good tube bender or a good friend somewhere a long the lines I find it hard to do cause I don't want a fontucky cage job like he has.  But with all seriousness yes I would like a cage just need to find somebody or someway to bend me the metal.
Oregon wheelin'
82' 2wd-4wd project
NITE KRAWLERS
There a company u think that can build u a cage to your specs with a program an they notch it an all! All u do is piece it together an weld it up man! I don't member the name of them right now tho!
nisota
Quote from: NITE KRAWLERS on April 15, 2013, 08:19:23 PM
That would be super cool!
Oregon wheelin'
82' 2wd-4wd project
