Author Topic: general transmision question 84 yota x cab  (Read 2485 times)
backseatwheeler
  • Turtle Points: 130
  • Member since Feb '05
« on: Feb 15, 2012, 09:32:38 AM »
yes i have a 84 Toyota xtra cab and am having problems putting it into gear. it used to shift just fine. only have to push the clutch down half to 3/4 of a pedal to disengage the clutch and take it out of gear. now i have to press the clutch down all the way to the floor board and it doesn't like to go into gear very easy. once in gear works perfectly just doesn't going into gear. im new to toy transmissions so any help  is welcome.
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Re: general transmision question 84 yota x cab
« Reply #1 on: Feb 15, 2012, 10:06:32 AM »
DId you check the fluid level
backseatwheeler [OP]
« Reply #2 on: Feb 16, 2012, 10:01:06 AM »
yes checked all fluids gear oil level and master cylindar level all good no wet spots from leaks either
junya92toy
  • Male Posts: 1,500
  • Drinking me beer
« Reply #3 on: Feb 16, 2012, 10:37:46 AM »
Bleed it? But more then likely youneed a new master and slave clyinder
« Reply #4 on: Feb 17, 2012, 07:25:25 AM »
is there any way to check the master and slave cylindar to see if there bad? any thing specific i should be looking for.
DRTYLUVN
  • Turtle Points: -19
  • Member since Oct '11
« Reply #5 on: Feb 17, 2012, 08:27:35 AM »
im having the same problems too
junya92toy
  • Male Posts: 1,500
  • Drinking me beer
« Reply #6 on: Feb 17, 2012, 08:29:04 AM »
well, they are prob bleeding out, not being able to shift is a good clue, but then again maybe you need a clutch, so push the clutch and have someone see if the slave moves, and if it does, then you might have to check the clutch or pull the master and slave off and bench bleed it, see if it leaks, or gets blow by
Last post Sep 08, 2005, 06:58:06 PM
by yotaboy79
Last post Jun 13, 2006, 02:50:14 PM
by black92se
Last post Dec 21, 2007, 06:23:13 PM
by 46&2
Last post Sep 20, 2010, 02:34:46 PM
by 1badeagle
Last post Jul 06, 2020, 08:01:57 PM
by Rocksurfer
