Adjust the brake pushrod
ive had this a few times. Might sound crazy but I crack the line coming out of the master, and have someoneone pump, i wait ill i see fluid come out and as its coming out, i close the line. I do this to bohth of them, and they usually hav air in them, even if i bench bled it beforehand. Worth a shot
If you do not bench bleed the MC before you put it on, you will have air trapped in it.
I dont see how it would move all of the sudden. Also when I took the master cylender off of the booster it appeared to be making contact. Although at this point anything is possible. Ill put it on my list of things to check again.
If it's not as deep, the brakes will be slightly on, covering up the bypass hole in the cylinder.
Can you explain this more. It is the same model master I replaced it with so the depths of the whole should be the same.
Started by 4DEES Engine
Started by ozzy93xtra Engine
Started by mmessier2 Toyota Pickup/4Runner Tech 1979-95
Started by 82rustbeast Engine
Started by sam2145871 Toyota Pickup/4Runner Tech 1979-95
