Dual's w/ 4.7 not low enough?????
Started by Cobbtunedsti, July 28, 2011, 06:46:31 PM
Cobbtunedsti
 I feel I could benefit from being even lower than I am!!!! I've talked to alot of people and everyone is telling me it's a bad idea to go any lower!! I know the dual 4.7's is a little much.. You'd have to put it in 3rd gear just to pull someone out LOL!!! Anyone know if there's a 4.0 kit or has anyone tried this combo???
blackdiamond
What type of wheeling are you doing where lower gears are necessary in your opinion?
Have you considered getting glasses so thing don't appear to be coming at you so fast!
IMMUDDY
Quote from: blackdiamond on July 28, 2011, 07:13:56 PM
HAHA, that's funny.
If I hit it just right, I might make it.
Cobbtunedsti
Yes I have lol.. I thought I was crazy:) I do alot of canyon crawling, rock crawler, trail stuff.. So is this a Dumb question???
TacoRunner
What tires size and r&p are you running?
www.4WHEELUNDERGROUND.com
[email protected]
brockbuilt85
i think there is a 5.0 or 5.1 ratio available, i know my brother has something like that in his dual cases and with 5.29 he is slower than most
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
Goldrush
theres 5.1 gears from advanced adapters. or you can do dual 2.28s
Rocksnail
run three cases if you want to be lower .then youll have all the gear selection  you want2.28 2.28 4.7
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
For most applications the 4.7 is way more than enough, the main reason for even having duals is that the 4.7 is already too low and having the 2.28 balances things out for general offroad travel while the 4.7 is there for crawling. When I had duals in my Samurai (Klune-V) I would have my front stock case in high 4wd most of the time and the Klune in low and very rarely would put the front in low.
locked 4x4
I use to have 4.7 gears in both cases with 35's and 4.56 gears.  It was awesome in the rocks for those special situations but it sucked for everything else.  I like to also do snow wheeling and it just wasn't practical in the snow.  I switched one of them out for a 2.28 and have been much happier.  Everyone once in a while i wished I had that low gearing, however overall its much better.
Cobbtunedsti
Cobbtunedsti
3 cases would be great!!!! Anyone think the drive shaft angle would be to great?
PhantomD aka Zach
I don't know how going lower would be of any benefit, marlin has triples, but seriously... the dual ultimate setup is crazy low as it is...
3rd Gen Extra Cab, Dual Cases, E-Lockers
Triples are for show, they have no real benefit.
Dingman.
True,  i run quads...
No i have two stocks, just got done with them.  Cant wait to test them out
rockin86runner
i got the 5.0s in the rear of my case and that way to low for me
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
:usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
Cobbtunedsti
I forgot about the 5.0!!! I'll take the 4.7 out and install it. Thanks guys. I heard the 5.0 is weak?? Is this true?? Anyone ever heard of these breaking??
Rocksnail
you really think that .3 is going to give you what you want? that is such a small amount that you wont even know that you switched.if you really need lower gearing witch i cant see why. Then go 3  cases and a hp front diff to fix your dline.
*** YELLER ***
except BACON
TacoRunner
[email protected]
howyadoin
I agree with the "get new glasses" comment...or maybe do some super duper reflex exercises like they do in NASA to work on your eye/hand coordination. :talkingn:  Honestly, to me, running low, low, low with 2.28/4.7/5.29's is almost sleep inspiring...only to be used in the absolutely most technical sections where tire placement is beyond crucial.  If you can't keep up with this combo, you should perhaps choose a new hobby....like quilting. :screwy:
"Flexes like a boneless hooker on muscle relaxers"
Cobbtunedsti
You guys are to cool!!! Look.. It's just a thought!!!! I just wanted too see what you thought and I got my answer..
blackdiamond
I think if you went with dual 4.70 gears you would regret it because you wouldn't have the stock low range.  Try it out by not using the stock low range for a while and see if you miss it.  Only use the 4.7 and 4.7 x 2.28 and see how happy you are.  Going 5.0 vs. 4.7 would be a waste.  The 5.0 is actually rounded up so it's less than a .3 difference.  You'll get that by airing down your tires.
I read about one guy with dual 4.70s and he wheeled in low low 3rd which is about low low first in the dual ultimate.  In Moab I often have to gear up a bit with 2.28, 4.70, 4.88 and 35's because a little momentum is required for a climb.  Low Low 2nd or 4.70 1st are the great options from my experience and 4.70 1st is the golden gear if you need a little bump.
Tofudude
where's bigmikes photo of 6 or seven cases?
GNasty 82
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Cobbtunedsti
^^^^ that's the greatest thing I've ever seen... LMAO!!!
Snowtoy
Quote
A 5-spd turbo transmission has a lower first gear, not sure how much difference it will make, but it might be just enough.
toe
prefix
dec = 10
suffix
(t)uple = is an ordered list of elements
http://en.wikipedia.org/wiki/Tuple
....   10 elements    .....
Me
