Devil Dog Runner
Started by *** YELLER ***, July 09, 2011, 03:49:03 PM
*** YELLER ***
                                  ANOTHER PAGE OF :bull crap:
Quote from: Shamb on August 21, 2011, 04:45:40 PM
what kind of shocks are you running?  you sure your shocks aren't blown out or something?
Billstein 5150 14'' rear
Billstein 5150 12'' front
they seam to be very difficult to compress so Im assuming they are good, talked to No - Idea this morning and we decided to remove the overload spring and replace it with more springs thinking that what I have is to soft, I have a set of Chevy 52''ers that im gonna rip into and find the 2 or 3 that i can use in my rear pack and try not to get any lift :crossed:
except BACON
twistedtoy92
Quote from: ** YELLER ** on August 21, 2011, 08:57:25 AM
what did you have in mind :headscratch: that was discussed in another thread but the cost would be the problem,  I can + or - leafs all day it just takes time :thumbs:
source a sway bar from a junk yard that will fit your rear end, attach it to your frame and then make links to your axle on the back side with some removable pins. then to disconnect the links will fold upwards into some brackets and you use the pins you pulled out of the axle side to secure the sway bar up on your frame. your runner would have awesome road manners then still flex like a beast on the trail. :beerchug:
MiniSimp
I think it's just Yeller swervin :talkingn:
*** YELLER ***
Quote from: MiniSimp on August 22, 2011, 08:11:18 AM
well this happens to be of NO use at all ...... dont come back until you can provide something useful to this problem :slap:
except BACON
MiniSimp
I'll provide something useful after I drive it. :twocents:
*** YELLER ***
Quote from: MiniSimp on August 22, 2011, 08:41:43 AM
Its been 2 years since we first had this problem ..... could ya help out a little more :slap:
except BACON
MiniSimp
lol ok.
Does it wobble while you are driving straight?
Is it the scary pitch that happens on turns?
*** YELLER ***
Quote from: MiniSimp on August 22, 2011, 08:56:53 AM
the pitch on the turns are what they are ... not that big of a deal after all its a crawler, as long as Im not drifting I think it will be fine
the problem is that there is SO much body roll, its better now than before i added the 2 extra springs, but still scetchy, feels loose at about 45-50 i can do 55 and it goes straight and no floating back and forth feeling, but at slower speeds 10-20 if I jerk the wheel it feels like there are 3 big dudes on each side rocking it back and forth to the point I have to slow down and its real scetchy at times.
except BACON
MiniSimp
Try pivot block locks. See BigMike's thread. That will take those out of the equation for street driving. The problem is that 4runners are so damn top heavy.
*** YELLER ***
Quote from: MiniSimp on August 22, 2011, 09:22:13 AM
yea I know LOL, No Idea and I were talking about this and he thinks I should remove the overload springs and replace the loss of them with some more leafs to stiffen it up a bit, what do ya think
except BACON
fordh8r
I was thinking more along these lines.  :yesnod:
Quote from: ** YELLER ** on August 22, 2011, 09:25:35 AM
This may still help but it won't eliminate the movement of the pivot blocks.
*** YELLER ***
Quote from: fordh8r on August 22, 2011, 09:27:41 AM
so you both think I should reduce the moement of the blocks first :thumbs: that will be allot easier than removing the springs over and over LOL, now I gotta find Mikes thread
except BACON
fordh8r
If it's the easiest place to start, I don't see why not. At least then you've eliminated that factor, right?
MiniSimp
Yep.
Just shove some square tube in there, maybe make a square tube horseshoe with a pin or something?
Try it.
*** YELLER ***
Quote from: MiniSimp on August 22, 2011, 09:35:03 AM
Yep.
Try it.
what does that even mean ??? why dont you shove some square tubing "up there"  :yupyup: sorry
except BACON
Quote from: ** YELLER ** on July 12, 2011, 09:30:01 AM
Thinking of mounting my Hi Lift here ........ and discuss   :blah: :biggthumpup:
2 bolts with holes drilled into them to accomidate hitch pins for quick removal welded to the bottom of the tire carrier
and 1 here to hold it place with same hitch pins for quick removal
from the front
WHAT DO YA THINK :cheese:
:usa: :beerwhack:
I know this was a while ago but I was browsing and saw this, a good friend of mine ran his like this on a Samurai. One day he did a slow roll on a hilltop the jack lifted his rearend and pitched his truck down which turned a slow roll into a full on barrel roll down the hill. If it would have landed solidly on his lid it would have stopped, but the jack tipped him over the edge.
*** YELLER ***
wow I totally didnt end up doing this, I layed it flat and added a shovel behind the Spare Tire but thanks for the heads up. Ill get a pic of what i did so you can see it
except BACON
*** YELLER ***
except BACON
*** YELLER ***
see layed down like a good Hi Lift :rofl2:
except BACON
Zs Confederate Toy
I have mine stood up like that. Right behind the cab on my truck.
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
Nice, you'll never lose that shovel. Must be leftover from the CJ :gap:
[threadjack]
Quote from: Zs Confederate Toy on December 20, 2011, 10:35:21 PM
I layed mine along the bed edge on my truck you can just see it in the pic.
[/threadjack]
Zs Confederate Toy
Quote from: Rocksurfer on December 20, 2011, 10:41:21 PM
[threadjack]
[/threadjack]
Yeah, I saw that lol. Jus wanted to share mine. Excuse my thread jack haha
ZACH
87 Rock Rat X
Trail Junky
*** YELLER ***
call 911 call 911 Ive been thread jacked . . .
yes occifer I can describe them one of them, was driving a red truck and the other . . . . was driving a red truck and . . . .no I dont think it  was Santa, there were no Raindeaerrr, plus Santa couldnt deliver all of those presents in Low LOw  . . . . in the same night DUH :smack:
except BACON
*** YELLER ***
Quote from: Rocksurfer on December 20, 2011, 10:36:31 PM
can you tell :eye: V :eye: I was trying to hide it :rofl:
except BACON
brockbuilt85
sit highlift sit, good jack
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
Quote from: ** YELLER ** on December 21, 2011, 06:25:59 AM
:rofl:
*** YELLER ***
Quote from: *** YELLER *** on July 20, 2011, 04:08:55 PM
ok I'll play
:usa: :beerwhack:
Cody we can take out the stereo and do the CB EQ and a switch plate
except BACON
brockbuilt85
THE POST IS ALIVE!
that will be plenty of room for all that, just need to get a plate with the right size holes in it and your set to jet!
Turd Box Build:
*** YELLER ***
yes its still alive . . . :yupyup:
update - having Brockbuilt install some LED's for me and then . . . :dunno:
1. Need to figure where to cut the second top I have so I can mount rack and keep shade on rear passengers   :help:
2. Got Marlin  :turtle: I do  :bowdown:
3. Great big battery, little bitty place to put it, used my boat battery since Runners was dead  :smack:
4. It's clean, now to get it to Brockbuilt for some LED install :gap:  :inthedark:
:usa: :beerwhack:
except BACON
