Devil Dog Runner
Started by *** YELLER ***, July 09, 2011, 03:49:03 PM
brockbuilt85
Devil dog to do list:
-untweak tire carrier
-fix winch so I tested everything and it seemed to be working good, motor was just not going. So I hit it with a hammer and it worked, then it didn't, then I hit it and it worked, then it didn't....... so I'm not sure what the deal is, everything is tight
-fix windshield washer reservoir- new pump ordered
-remove pivot blocks
make plate or something for twin sticks to cover hole better- used a piece of rubber mat to better cover the hole under the boot, just need to attach it
-full gear oil drain and fill
-fix fair lead......my bad
-find some full doors rekey new doors
-air tank/compressor
-rebuild leaky knuckles
-air conditioner
-rebuild leaks steering box- gasket set in hand, need to remove box and get it to a guy I know :gap:
[/quote]
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
brockbuilt85
-fix winch need to rebuild the motor
-air conditioner
-rebuild leaks steering box- I cleaned it up and tightened all the lines I'm going to see if it still leaks and go from there
[/quote]
Turd Box Build:
brockbuilt85
-Exhaust- need to make an appointment for a new exhaust, awaiting tax return
-untweak tire carrier- should be on its way to fordh8ers meow
-air conditioner
Turd Box Build:
brockbuilt85
remove pivot blocks going to go the rout of big mikes one way lock out to see how that works, got the tubing cut just need to drill the plates.
-air conditioner
Turd Box Build:
brockbuilt85
also thinking about getting one of these to replace the one i broke
Turd Box Build:
Tallchevy
I'm starting to get the hint that I need to get the one I have to you!
87 4Runner redo
mudmaster
Quote from: brockbuilt85 on March 07, 2018, 02:34:38 PM
Any measurements?
Time to go wheelin!
brockbuilt85
Quote from: Tallchevy on March 07, 2018, 08:34:00 PM
I completely forgot about that!
Turd Box Build:
brockbuilt85
remove pivot blocks put the one way eliminator together just need to test drive
-fix fair lead...... just needs a tack weld ro repair
-air conditioner
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
-Exhaust- new one saturday!
-air conditioner
Turd Box Build:
brockbuilt85
#671
-Exhaust- new one Saturday makes a difference for sure! A lot more pep. Still only a 22re lol
-adjust valves
-air conditioner
Turd Box Build:
brockbuilt85
#672
-untweak tire carrier- should be on its way to fordh8ers meow thanks dude!
remove pivot blocks put the one way eliminator together just need to test drive seems to make a difference, shes still a highly modified top heavy pregnant dog tho
-fix winch- need to rebuild the motor- works with love tap
-rewire tire carrier and attach new aux brake light
-adjust valves
-rebuild leaky knuckles- seals in hand, will be a project for this spring
-air conditioner
ordered this aux brake light for the tire carrier
Tire carrier back on
Turd Box Build:
brockbuilt85
-adjust valves
-find some full doors rekey new doors (?)
-air tank/compressor- thinking about doing one of these- https://www.amazon.com/dp/B00VROSSKM/?coliid=I1MJS1RJRWVFSZ&colid=G58PAKCWH8XH&psc=0&ref_=lv_ov_lig_dp_it
-air conditioner (?)
tire carrier back together and done
Turd Box Build:
AZ Rockit
82 Long bed, 22r with 83 celica EFI, 31s
84 Xtra cab, 22r, Chevy springs, 31s
85 4Runner, 3rz, R151F, 244:1, 37s
85 Long bed, 22re Performance Stage 2 engine, 32s
85 Short bed, 22r
89 4Runner on a 94 truck chassis, just a roller (Montana Runner)
Unclejarhead
Unclejarhead
 :king:  :usa: :beerchug: :clap2: :turtle3: :turtle:   soooo, how's the Devil Dog Runner doing ??? ??? ???
Blingn
I saw it wheel at lagrange
brockbuilt85
Hibernating, soon to come out of hibernation.
Turd Box Build:
87ricerunner
