I put on bigger tires and needed a formula to calculate what new gears I need to compensate, so here is what I found....
A simple tire / gear calculator is to multiply your new tire diameter and your old gear ratio, then divide by your old tire diameter.
example: 30 inch tires and 3.50 gears, and now you put on 35 inch tires: (35 x 3.50) divided by 30 = 4.08 gear ratio to compensate.
If this has been posted before, sorry.
