Author Topic: gear ratio to tire size  (Read 4114 times)
toyotamobing
  • Turtle Points: -8
  • Male Posts: 1,244
  • Member since Sep '05
    • Poly Performance
« on: Feb 29, 2008, 06:58:24 PM »
im woundering what the ideal gear ratio to tire size is??? for example im running 33s with 4.88...good? bad? and for other gear ratios like 4.10, 4.56, 4.88, 5.29...ect.
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
  • Online Gold Turtle Award
  • Turtle Points: 1622
  • Male Posts: 8,730
Re: gear ratio to tire size
« Reply #1 on: Feb 29, 2008, 07:01:48 PM »
4.10s good for 31s
4.56s good for 31-33s
4.88s good for 33-35s
5.29s good for 35s+
5.71s good for 35s+ with more torque
this is generally for the toyota crowd
domestic trucks use a whole different system....
toyotamobing [OP]
  • Turtle Points: -8
  • Male Posts: 1,244
    • Poly Performance
« Reply #2 on: Feb 29, 2008, 07:13:25 PM »
so im geared properly for my 33s. would this put me close to stock ratio?
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
  • Male Posts: 8,730
« Reply #3 on: Feb 29, 2008, 07:16:10 PM »
4.88s with 33s is good
toyotamobing [OP]
  • Turtle Points: -8
  • Male Posts: 1,244
    • Poly Performance
« Reply #4 on: Feb 29, 2008, 07:41:25 PM »
ok and what about having a welded carrier?
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Redbeard1
  • Turtle Points: 54
  • Male Posts: 414
  • Member since Mar '07
    • Project Pete
« Reply #5 on: Feb 29, 2008, 08:12:22 PM »
nothing wrong till the welds break...
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
 __________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
  • irish redhead texan, interesting combo
« Reply #6 on: Feb 29, 2008, 08:28:54 PM »
completely differant gearing than domestics haha
read and comment :whip:
USAF EOD tech
Hammerhead
  • Turtle Points: 112
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
« Reply #7 on: Feb 29, 2008, 08:49:08 PM »
4.10s good for 31s
5.29s good for 35s+
jimbo is right on for a 22r  :yesnod:
My 350 on 38.5s is just right with 4.11s  :gap:
'85 4runner
red
  • Male Posts: 1,616
« Reply #8 on: Feb 29, 2008, 08:54:04 PM »
exactly, my blazer is running 3.08's with 33"s with a 327 gasser, great setup.
USAF EOD tech
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
« Reply #9 on: Feb 29, 2008, 08:54:38 PM »
gotta love them tiny engines.
GDubb5150
  • Male Posts: 45
  • Member since Jan '08
« Reply #10 on: Mar 01, 2008, 11:41:45 AM »
Isn't there a method for checking gear ratios by marking the drive shaft and then rotating the tire and counting how many turns one or the other makes in relation to the other?  I would like to figure my ratio out but dont remember the specifics.  Does this make any sense or am I way off base?  :dunno:
Rock It Till The Wheels Fall Off!
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #11 on: Mar 01, 2008, 12:44:57 PM »
That makes sense. Rotate the drive shaft until the tire does a full rotation and count the rotations of the drive shaft. But this will only give an estimate for the ratio, it will be difficult to find the decimal. Check your vin#, if the third is stock, it'll tell you.
hollywood_toy90
  • Male Posts: 79
« Reply #12 on: Mar 01, 2008, 05:34:48 PM »
there is a code in your door jam that will tell you too!
red
  • Male Posts: 1,616
« Reply #13 on: Mar 01, 2008, 06:00:11 PM »
yes gdubb you can do that, its the number of driveshaft rotations to 1 rotation of the wheel. like mentioned before though it will only give you a rough number, not the exact ratio.
USAF EOD tech
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,782
  • Member since Dec '06
  • NFM Customs
« Reply #14 on: Mar 01, 2008, 06:48:35 PM »
or you can remove the DL from the third and the end of the pinion gear shaft is color coated, pink is 4.10, green is 4.30, i mix up the rest   :headscratch:
toyotamobing [OP]
  • Turtle Points: -8
  • Male Posts: 1,244
    • Poly Performance
« Reply #15 on: Mar 02, 2008, 10:14:36 PM »
now what about the acuracy of the speed-o
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Duffil
  • *lurker*
  • Turtle Points: 88
  • Male Posts: 4,832
  • -Hack-
    • PhotoBucket
    • Buy me a soda
« Reply #16 on: Mar 02, 2008, 10:55:37 PM »
with 33s and 4.88s, according to GPS on my nextel my truck is within 2-3 MPH of the speedo.
Blingn
  • Turtle Points: -14
  • Male Posts: 2,340
  • Member since May '06
cam011
  • Male Posts: 81
  • Member since Apr '07
« Reply #18 on: Mar 05, 2008, 05:41:10 PM »
I don't trust this method myself, I pulled apart an e-locker 3rd with 4.30 gears and it had pink paint on the pinion nut. It seems to work on the early ones though, maybe Toyota changed their color designations.
toyotamobing [OP]
  • Turtle Points: -8
  • Male Posts: 1,244
    • Poly Performance
« Reply #19 on: Mar 05, 2008, 06:16:40 PM »
how hard is it to swap the pinion flanges??? my front third is a different bolt pattern and size
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Last post Jan 09, 2004, 06:32:00 PM
by 79coyotefrg
Last post Sep 13, 2004, 04:13:24 PM
by Hyena
Last post Nov 24, 2005, 05:08:05 PM
by 11 Bravo
Last post Apr 25, 2007, 11:07:46 AM
by Yota Up
Last post Mar 11, 2013, 07:13:25 PM
by H8PVMNT
