As mentioned dual cases only effect your low range, gearing, so you want to match your gears to tire size just as you would do if you didn't have duals. 4.56 or 4.88 would put you close to the stock ratio of 28's and 4.10's as you can get. 4.56's would be a little under geared, and 4.88's a little over but would allow you to upgrade to 33's w/o having to change gear ratios. However if you plan on running 33's anytime soon, you might consider going w/5.29's, a lot of people like the performance combo of 33's and 5.29's w/a 4cyl. The 5.29's would also set you up for running 35's, if/when you wanted to run them.
Started by toyotamobing Tire and Wheel Tech
Started by David General 4WD Discussion
Started by mdtrail-toy Toyota Pickup/4Runner Tech 1979-95
Started by Grimmjow Tire and Wheel Tech
Started by BCWheelerMan New Member Check-In!
