MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 6 Guests are viewing this topic.
Duffil
MiniSimp
fordh8r
Could it be a winchy-winch?  :dunno:  cuz that would be cool... :gap:
skipnrocks
Quote from: fordh8r on December 01, 2007, 07:53:15 AM
That sounds like a good guess actually, it never crossed my mind!!
WILLYNILLY
Wermz84
You finally decided not to ba a cheap b*std, broke down and got some Long's?   :dunno:   :gap:
I like to Drive!
MiniSimp
Quote from: tom w. on December 01, 2007, 06:12:13 AM
:headscratch: :smack:
:therethere:
:headscratch:
Quote from: skipnrocks on December 01, 2007, 11:37:34 AM
:headscratch:
Quote from: Wermz84 on December 01, 2007, 04:53:50 PM
:talkingn:
MiniSimp
Nothing special, just posting these so HisDudeness can see them.
Rock Slider - 0 degrees
Rear Pinion - 5 degrees up
Transfercase Flange - 3 degrees down
unclejpl4x4
skipnrocks
Quote from: MiniSimp on November 30, 2007, 10:10:32 AM
I'll give you a hint tom, it has a 210:1 crawl ratio, but it's not too big on horse power. No, it's not an RC car.
So are we gonna ever find out?  or did I miss it?
WILLYNILLY
MiniSimp
MiniSimp
 :greengrin:
skipnrocks
Cool winch!!!!   Its almost to shiny for your truck :nonono:  but not quite!!!   :thumbs:
WILLYNILLY
MiniSimp
 :king:
*** YELLER ***
Dude that rocks  :bowdown:   and....  :down:    um.....  :headscratch:   well......  :dunno: crap....  :tantrum:   now I have more work on YOUR truck  :flamer:  to do  :slap:
When do we work on DA RUNNER  :dunno: :sad2:
:usa: :beerwhack:
except BACON
fordh8r
Quote from: oldyellercj on December 07, 2007, 07:41:48 PM
:usa: :beerwhack:
:slap:  Not until your done making all the mistakes on his rig... :gap: :disturbed:
Oh, I told you so.....he got a winch!  :woohoo: :hyper: :woohoo: :hyper: :woohoo:
46&2
It looks so pretty all wrapped up nice and tight in the box almost dont want to see it get dirty  :greengrin:
fordh8r
#1909
Hey Mini, now you can get yourself off the pile next time you break... :gap: :disturbed:
unclejpl4x4
DTB
MiniSimp
Do you think this winch mount will be strong enough?
I'm trying to keep it as close to the radiator as possible. With this mount the winch will stick out 3.5" from the front of the crossmember, I plan on plating the front crossmember to add strength, but what else should I do?
IronClad
the front of toyota frames are kinda weak  id run some triangle braces down the top of the frame.  the drivers side will be a little tricky depending on how your box is mounted  but  it honestly needs it imo.  the solid axle frames love to crack right behind that front cross member and with the loads that the winch are going to put on it..  gonna be alot worse than normal.  just IMO   otherwise  looks good !
Annihilation  Fabrication
Do you need a Hammer?
MiniSimp
I've also thought about replacing the front crossmember with 2"x2"x.125 box steel and work off of that. :dunno:
IronClad
#1915
you shouldnt need to but it couldnt hurt.  let me dig through my pics and see if i can find a pic of my old mount, it was setup for a removeable winch place setup but the same idea applies
Edit
Cant find anything =\   but you pretty much have the same thing going as i did on my old truck  less the top braces which i think you need since you are running stock spring hangers and theres no good way to brace the under side of the frame  from breaking  (drop hanger makes this a piece of cake)   but id say you are set
MiniSimp
Here is what I have for measurements, blue line is radiator
skipnrocks
Do you have gussets to the X-member from the frame?   If you could put some in there, I dont see any reason it wouldnt work...
WILLYNILLY
MiniSimp
I'm either going to gusset the hell out of the stock crossmember and plate it as well, or just tear it out and replace it and gusset that, either way there will be some strengthing work done... :headscratch:
Cheesemaker
Why don't ya just get a Marlin front bumper?  Already set up for a winch!  Just bolt it up!
