Author Topic: Issue with pinion nut after replacing seal.  (Read 2488 times)
scott.475
  • Turtle Points: 3
  • Member since Dec '03
« on: Apr 07, 2011, 06:59:06 PM »
Guys, this is weird I think. I put a new Marlin HD seal in my '91. Before loosening the nut I marked the socket and flange and was SUPER careful when I counted the number of turns. 10 turns exactly to get the nut off. After I got the new flange in and went to tighten the nut I can only get it to 9 turns. I probably could have muscled it to 9.5, but was worried I might crush a sleeve or something in there more than I should. I have taken it back off a couple times to make sure I am counting right, now it is 9 turns on and off. The manual says the nut should be 145 ft-lbs, which takes it to exactly 9 turns.
So, what do y'all think? Is the 145 ft-lbs on the nut going to be okay? I'm really nervous now. Also, is it really necessary to check preload after doing this? Manual says it should be 8-11 in-lbs, but my wrench only goes down to 25. I guess I could spring for a beam type wrench if I need to.
Anyway, any advice on my pinion nut situation is appreciated.
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: Issue with pinion nut after replacing seal.
« Reply #1 on: Apr 07, 2011, 07:02:14 PM »
Its done, in my opinion,  If its a crush sleeve, you need a new one.
scott.475 [OP]
  • Turtle Points: 3
« Reply #2 on: Apr 07, 2011, 07:09:37 PM »
If I over crushed the sleeve, wouldn't it tighten more than the 10 turns somewhat easily?
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
« Reply #3 on: Apr 07, 2011, 08:03:25 PM »
If there is no slop in the flange then your done. The crush sleeve is for pre-load on the pinion bearings only. As long as the flange can turn with a little smooth resistance your good.
9... 10... your good enough :thumbs:
scott.475 [OP]
  • Turtle Points: 3
« Reply #4 on: Apr 07, 2011, 08:58:56 PM »
Dude, this is making me laugh. Like those scenes out of Mr. Mom: "Whatcha gonna wire it in, 120?" "120, 121, whatever it takes"
"My God, what'd you use, a .38?" ".38, .39, whatever it takes."
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Apr 08, 2011, 06:08:42 AM »
torque to 145 dont worry about the number of turns on the pinion nut  :thumbs:
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #6 on: Apr 08, 2011, 06:58:31 AM »
  :laugh:
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #7 on: Apr 08, 2011, 02:30:34 PM »
Thats why specs are in 'ft-lbs' and not 'full nut rotations'. Your good to go.
You'll never take me alive
scott.475 [OP]
  • Turtle Points: 3
« Reply #8 on: Apr 08, 2011, 06:23:30 PM »
Okay guys, appreciate everyone's help, but still quite nervous about this. I decided to go ahead and put a new pinion nut on, so today I redid everything. I noticed when I had the flange off that the pinion would slide into the housing a bit, so I put the flange on, then the nut just a little, then pulled on the flange to pull the pinion out as I started tightening, figuring this would seat the bearings correctly before tightening. Tightened it down to 145, and now the pinion feels much harder to move than before, significantly harder than the front end.
Should I have just let the nut pull the spindle into place instead of holding it out with the flange? I'm thinking now I should just pull the pumpkin all together and do it that way. Sorry for seeming paranoid, I just don't want to burn up the gears or anything. I suppose my only risk on this particular issue would be burning up the pinion bearings, no?
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #9 on: Apr 09, 2011, 09:33:49 AM »
Check out gearinstalls.com. You'll learn a lot!
scott.475 [OP]
  • Turtle Points: 3
« Reply #10 on: Apr 09, 2011, 12:38:10 PM »
Okay, went out this morning, jacked up the rear end and pulled off the wheels in anticipation of pulling the third. After I got the wheels off I went under and gave the flange a turn and it moved way smooth without the weight of the wheels/tires. Tested with a torque wrench and it seems to be good, so I feel a lot better about it now. I guess I should have known the weight of the wheels would do this, but at least I will know for next time.
Thanks everyone for your input. This all came about because I was putting in a new Marlin HD clutch, so looking forward to see how that works. The old one was in bad, bad shape.
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #11 on: Apr 09, 2011, 03:00:20 PM »
Just run it for a while. Then check it again. Remember, the pre load is suppose to be measured this the third removed. So mostly check that the resistance is smooth with the tires and even the drums off :thumbs:
Last post Oct 04, 2005, 05:51:32 PM
by GoYoTaGo
Last post Sep 23, 2010, 09:54:09 PM
by DD85runner
Last post Apr 07, 2009, 10:40:26 PM
by Marlin
Last post Aug 30, 2009, 01:12:38 PM
by sparkys83yota
Last post Jul 27, 2012, 10:44:36 AM
by woodyth
