so easy, these trucks are made to be serviceable by anyone, not like newer Toyota trucks.i have a friend who owns a machine shop so i used his press,while you are at it replace the wheel cylinder for your drum brakes. you have to pull the axle shaft to change it out and it is a complete pain to do it. might as well do it all while you are in there.
Pretty strange, I have changed wheel cylinders on both non-IFS and IFS axles and have never had to press the axle off to do it.There is a way to change the bearing without a press and SST. Most people will not do it because they think it will mess up the axle. Never seen it mess up and axle and it works great if you do not have access to a press and SST. Here is a link to it.http://www.4x4wire.com/toyota/maintenance/rear_axle/wheel_bearing/
Started by 1982toy Engine
Started by Huhwhye Engine
Started by hilux-1983 1979-1983: How-To Guides
Started by scott.475 Toyota Pickup/4Runner Tech 1979-95
Started by woodyth Newbie Questions
