Replacing rear seal on 87 toy pickup. Hard?
Started by woodyth, July 12, 2012, 05:09:32 PM
woodyth
The seal coming out of my transfercase is leaking. I need to replace it. It looks pretty self explanatory remove bolts push back drive shaft, pull out flange. remove seal, put new seal on and rebuild? Are my predictions correct? or is there something I should know.
Thanks
Woody
2manytoys
Thats pretty much it. Assuming your flange isn't grooved real bad. Marlin's Eco-seals work great.
woodyth
parts store lists a bearing also, would it be wise to replace that also?
andeze
I had the same problem last year, popped in marlins eco-seal in and it was done in minutes. Has not leaked a drop since, It is nice to get an easy fix once in a while.
emsvitil
Quote from: woodyth on July 13, 2012, 03:54:32 PM
No.  Highly unlikely that it's bad.
If that bearing is bad, all the rest of them probably are too.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
woodyth
do i use the carquest one or wait 2 weeks for the MC ECO?
Also quick question, LCengineering street header or doug thorley ceramic?????
emsvitil
Never do it again with the MC one.................
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
woodyth
