the output shaft in you TC should NOT move. If it does then you might want to think about checking your output bearing. Pictures would help a lot!
i just went and got the 30mm socket to tighten the nut so hopefully that will help if not i will replace the seal and rear bearing and go from there, the t-case still shift fine and tight, no grinding of any sorts so i doubt a complete rebuild is needed but then again you never know what i might find when i take the rear cover off.
I would check the rear shaft in the t-case for run out, it could be bent.
Started by johnyreb69 General 4WD Discussion
Started by PA_taco_13 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by toyrunner87 Toyota Pickup/4Runner Tech 1979-95
Started by vetta Toyota Pickup/4Runner Tech 1979-95
Started by dot 1 Engine
