Engine gots the shakes!
Started by johnyreb69, May 04, 2004, 07:43:16 PM
johnyreb69
I just converterted my 86 4runner from auto to manual, problem now is that my H4WD gear doesnt work the H2 and L4WD work fine. Another problem is that my engine shakes really bad now, im thinkiing it has somehting to deal with the ideal speed of the engine going from auto to manual (Its an EFI BTW) any sugenstions to either of my problems?
-- Fear is our only enemy
    Stand tall in the face of your enemies
    And you will conquer --
Bernabe Frank Rodriguez, EIT (Thats Me!)
Ferg
Double check and see if you have the corrct flywheel for the year of engine if it came with manual trans.
Brandon
it shouldn't shake no matter what. Make sure it is firing on all cylinders (pull plugs and see what happens)
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Marlin
#3
On a gear driven t-case, you must shift thur H4 to get to L4. What happens when you go into H4? Do you have a t/case twin stick? Which trans/t-case did you install? Were they a matched unit or just spare parts?
Changing from auto to stick shift will not cause a miss. Have you checked for vacume leaks, bad spark plug wires?
Marlin
johnyreb69
Quote from: Marlin on May 04, 2004, 09:27:37 PM
Marlin
I have a stick in the tranny and one in the t-case, when i shift into H4 nothing happens its as if its in nuetral, but nuetral is right below that gear
                H2
           L4   |
           ------H4
L4 works and so does H2. This is what it looks like. Yeah its the Fly for that year tranny>
Prismo
I am going to ask a very dumb question here & it is not meant to be negative. I am trying to cover all of the bases. You did put a pilot bearing in the block before you installed the tranny?
johnyreb69
Yes, everything is as a manual should be the pilot the fly, the clutch disk and cover, the other beraring that goes in the bell and connects to the shifting fork.
84runner
does it just  shake at idle ? or all the time ? or just certain parts of the rpm range ?
johnyreb69
it shakes when i shift into gears and when it idels. I think its the spark plugs, going to check that out Friday when i have time... damn so close yet so far away from playing with my new toy :smack:
Marlin
What type of truck and drivetrain are you running?
In Toyota land we shift as follows;
      L4
H2   N
H4--H4
Marlin
johnyreb69
 :smack: Im such a newb, didnt know that, thought it was the other way around, THANKS! all i got now is the shakes! Jesus im so dumb, super newb BTW :smack: :smack: :smack: :smack:
johnyreb69
86' 4Runner EFI 4 cyl, put in a tranny from an 88 alll stock
TigerToy
Everyone has to start somewhere.  My first week working at a shop, I put lug nuts on backwards and crashed into a car in the parking lot (no damage though).   :smack:
johnyreb69
does the t-case have to be in a gear in order for the tranny to work? I put the tranny in 1st gear and leave the t-case in N and she wont move, when i leave the t-case in H4 or any other t-case gear and put the tranny in gear she will move. Is this normal or should the tranny work even if the t-case is in N?
83yota
with the t-case in n you should not move. unless your on a hill or got someone pushing you. also dose your truck still shake if you are on paved roads and not logging roads or bumping up rocks LOL :hammer:
johnyreb69
I'd like to thank everyone that replied to my post on switching out my auto tran for a manual one. It was alot of help, it was simpler than i thought it was, i will post a step by step for others to follow as well, please feel free to coment on that as well. We must share our knowledge with each other, after all thats what make the USA the best damn country out there. :driving: Keep on 4 wheeling!
Prismo
What was wrong with the engine?
Quote from: johnyreb69 on May 06, 2004, 10:30:51 PM
:headshake: someone tell me hes joking  :dunno:
dude,  it goes like this, engine + tranny + tcase
if tranny is in N you dont move  :smack:  if tcase is in N you dont move,  :dunno:  if engine is not running you dont move,   make sure the plug wires are on the right plugs, start engine,  put tranny in 1 put tcase in 2h for pavement or 4h and 4L for the dirt
brainlessfool
good to know that I'm not the only brainlessfool on the borad :thumbs:
KYOTA
