On a gear driven t-case, you must shift thur H4 to get to L4. What happens when you go into H4? Do you have a t/case twin stick? Which trans/t-case did you install? Were they a matched unit or just spare parts?Changing from auto to stick shift will not cause a miss. Have you checked for vacume leaks, bad spark plug wires?Marlin
does the t-case have to be in a gear in order for the tranny to work? I put the tranny in 1st gear and leave the t-case in N and she wont move, when i leave the t-case in H4 or any other t-case gear and put the tranny in gear she will move. Is this normal or should the tranny work even if the t-case is in N?
We must share our knowledge with each other
Started by lucky7 « 1 2 » Rigs For Sale
Started by vetta Toyota Pickup/4Runner Tech 1979-95
Started by Zs Confederate Toy New Member Check-In!
Started by skin6061 Toyota Pickup/4Runner Tech 1979-95
Started by dot 1 Engine
