Author Topic: Small Tick In Motor  (Read 4891 times)
baggedyoda
  • Turtle Points: -2
  • Male Posts: 24
  • Member since Nov '10
  • C.W.B
Small Tick In Motor
« on: Dec 22, 2010, 08:12:30 PM »
i have a small tick comin from my motor it almost sounds like a lifter but its not but similar sound any ideas timing belt maybe idk
If I Was Your Heart Would You Let Me Beat!!!!
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Small Tick In Motor
« Reply #1 on: Dec 22, 2010, 08:29:19 PM »
Type of motor would help............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
baggedyoda [OP]
  • Turtle Points: -2
  • Male Posts: 24
  • C.W.B
« Reply #2 on: Dec 22, 2010, 08:31:56 PM »
84 22re
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #3 on: Dec 22, 2010, 08:36:30 PM »
Adjust the valves and make sure the timing chain guides are there
(I'm not sure when toyota started with the POS plastic guides for the 22R)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
baggedyoda [OP]
  • Turtle Points: -2
  • Male Posts: 24
  • C.W.B
« Reply #4 on: Dec 22, 2010, 08:37:53 PM »
ok thanks ed
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #5 on: Dec 23, 2010, 04:45:06 AM »
Could just be noisy injectors....
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #6 on: Dec 23, 2010, 05:24:42 PM »
How do you hear the injectors over the valve noise?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Momentum Man
  • Lego Enforcement
« Reply #7 on: Dec 24, 2010, 04:52:12 AM »
It may not be valve noise, the injectors can get real clicky to the point they sound like lifters as he stated in the OP.
boneyard customs
  • Turtle Points: -10
  • Male Posts: 31
  • Member since Dec '10
  • Build it yourself and wheel it !
« Reply #8 on: Dec 29, 2010, 11:57:34 PM »
Fellow boneheads.......... Toyota has always been using the plastic timing chain guides. The metal ones are aftermarket. If you are using the after market steel (plastic coated) guides they will make a similar sound. When the plastic wears off. I rebuilt a buddies 22RE after about 40K miles he mentioned that the valves needed adjusted. After doing so. the noise was still apparent. mmmm after further checking we noticed plastic in his oil. Thus thinking it may be the guides. In which it was. We replaced them with Factory chain and guides. Problem solved.  There are alot of companies making cheap overhaul kits nowadays. Be careful who you buy from. Just because it was made in Japan (same place Toyota was) Doesn't mean it carries the same quality. Beware of cheap imitators from Mexico.
86YotaKing
  • Turtle Points: 2
  • Male Posts: 60
  • Member since Nov '09
« Reply #9 on: Jul 12, 2011, 07:19:01 PM »
Very well could be timing guides they are made of plastic
1986 toyota 4runner 4x4 6 inch lift with 39x13.5s 5.29s
2000 taco Arb front bumper, 4 inch lift 33's not a project
Newest project 86 taco in progress wifes pinkcamo
Seeds
  • Male Posts: 93
  • Member since Sep '11
« Reply #10 on: Oct 13, 2011, 11:16:46 AM »
Turn up the stereo! Problem solved
Romans 12:2
rattlers
  • Turtle Points: -68
  • Member since Mar '11
« Reply #11 on: Oct 13, 2011, 11:27:17 PM »
i have an 85 22re and a 92 22re both of which "tick" but the 85 is way quieter. i have tried everything to quiet down the 92 but finally realized with a stethascope that it was indeed the injectors making the noise which are different between these trucks. i have considered buying 85 injectors for the 92 but the plugs are different and what a lot of work anyway.
I think the 85 injectors are low impedance and the 92 have high impedance fuel injectors , but I dont no if that would make the 92 high impedance injectors louder
__________________________
ll_______ll_______ll__TOYOTA_ll
ll_______ll_______ll____85____l
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« Reply #12 on: Oct 14, 2011, 05:49:07 AM »
Take a long screw driver touch the tip to where you think the noise is coming from and put the handle to your ear. You will be able to hear it.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #13 on: Oct 14, 2011, 06:54:48 AM »
better a tick than a flea  :yesnod:
TURBO
  • Turbo Extremist
  • Turtle Points: 65475
  • Male Posts: 706
  • Member since Sep '04
  • Capt. Insaino shows no mercy
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Marlin is like the Chuck Norris of the rock crawling world.
jsnell
  • Member since Jan '12
« Reply #15 on: Jan 22, 2012, 05:13:22 AM »
I set mine at 007 and 011, and the noise went away. Steel guides are overrated, and part of a good maintence practice would be changing the chain and guides
around 120 to 150000 anyhow.
I put my thumb on the rockers while it was running to find the noise maker. Be sure to pull out the adjuster screw to check for wear, otherwise you'll never get a true reading.
« Last Edit: Jan 22, 2012, 05:19:23 AM by jsnell »
rattlers
« Reply #16 on: Jan 22, 2012, 02:19:26 PM »
I think the low impedance fuel injector is louder
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #17 on: Jan 22, 2012, 04:15:46 PM »
wow this thread is old!
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • You see it we wheel it
« Reply #18 on: Jan 22, 2012, 05:40:01 PM »
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #19 on: Jan 22, 2012, 07:19:35 PM »
Could also be a valve cover that is tightened down too far - the timing chain will slap on the inside of it.  I've seen this with people that keep tightening down the valve cover to try to fix a oil leak.
Last post Aug 28, 2002, 04:11:32 AM
by Doc
Last post Dec 15, 2006, 05:11:37 PM
by mado13
Last post Feb 06, 2007, 05:44:58 PM
by RRMike
Last post Aug 06, 2008, 10:47:54 PM
by yotakid707
Last post Apr 25, 2010, 12:47:04 AM
by havik
