Project: More Clearance 2- INSTALLED!!!
Started by Hyena, January 06, 2005, 08:14:19 PM
Gtown
Ignore the haters brad, :pokinit: looks good, half these fools couldn't even tie their shoes in high school letalone shave an axel housing.  I think i'll be in town on the end of april, mabey we can go to prarie city and smash some :pokinit:.
Ben
jeeps are like poopie richard, every fa@*ot has one
TacoRunner
I still have a few pin hole leaks in mine. One of these days ill get to it
www.4WHEELUNDERGROUND.com
[email protected]
Hyena
Quote from: Gtown on March 09, 2005, 09:17:26 AM
Ben
Sweet.  Hopefully i will have my axles done by then.
TrackVino
No Power
Those axles are sic :biggthumpup:
I'm always shocked to see what people
are doing to these toyotas :gap:
It looks like you did really good work
on those axles :drooling:
Keep up the good work :beerchug:
Roll me back over !!!
Hyena
thank you.  I just need to send in my birfs to bobby to have then heat treated.  then i can scavange up a couple more things and it will go in.
Hyena
So James and I installed the front axle today.  Took almost 5 hours total for the front.  We also got the back axle off and torn apart.  I welded up the open third about 10 minutes ago.  the third with the detriot is now in the front with the new Longs.  I just have to put the rear axle back together with the new clearanced housing.  Pictures soon to come.  I am going to eat dinner now and then will get back on it after dinner.
Hyena
My truck is fawked for at least 3 days.  I need a new rear axle bearing for the drivers side.  and i aslo need a bleeder falve for the IFS rear axle.  appearntly they are different then the non IFS rear axles.  Here are some bleary pics.  I will take better ones tomarrow hopefully when it is lighter and of my mom doesn't have the camera.
Hyena
last ones
Hyena
this should show "about" how much more clearance it gave me.
Makman
Pretty burly.  :thumbs:   Now you just need to go bash it on some rocks and let us know how it does. :driving:
Did you end up with any pinhole leaks or are they all sealed up tight?
If it never breaks, people can only speculate how much it was overbuilt.
Hyena
#72
I haven't seen any leaks so far.  I was expecting some but i got lucky.
Edit: the front leaked a little over night from the bottom of the pumpkin.  So it wasn't leak proof.  I welded it up and grinded it down.  the rear hasn't leaked yet.
Hyena
Little bit better pictures.  Seems there is something wrong with the camera, always bluury on the left sife of the pics.
Hyena
more.  Shock mounts i fabbed up today from scrap metal.
Hyena
more.  Front axles had 11 1/2 inches of ground clearance under the pumpkin.  Can't measure the rear yet becasue the axle shaft is still out.
Hyena
last.  Poor truck has a broken leg.
TrackVino
Truck is looking really good, but why are your pictures a little fuzzy?
Clean your lense and hold the camera still!!
Hyena
Quote from: Hyena on April 24, 2005, 03:24:25 PM
Thats why.  And we finished it up today.  Toy on 40's replaced my rear axle bearing.  Me and James (Jack8542) brought the axle home and put it in.  We then bled the brakes and took it for a spin.  the brake pedle never felt good.  We kept bleeding them and it didn't work.  I then noticed brake fluid coming out of the passenger front brake line.  I looked at it and found a hole.  We repalced the brake line with a spare one i had and bled them again.  they felt better but not great.  Im gonna drive it to school tomarrow and finnish it there.  no pictures though.  my mom took the camera and she won't be back untill thursday.
Hyena
Linse is clean and it camera was still.  It never used to make the pictures blurry like that.  o well, my mom will find out and maybe get it fixed.
Hyena
O :pokinit:, i forgot all about this thread.  Well, it has been about 9 months since i put them under the truck and they are killer.  The housing are holding up great.  the only problem is that they both leak from the third member to housing flange.  I have had them apart both a couple times to try and fix the leak but it comes back.  Maybe it got warped when i did the final welding.  Weird, i am not woriied about it.  the front housing isn't even warped after doing full-lengthed welding beads on the top gusset.  I have dropped the dif on some rocks hard and they are still holding up.
burnyota
nice job, how many hour do you think you have in the shaving Hyena? :beer:
Hyena
I have no idea.  Not as much as you would think.  I only got to work on them a couple hours a day if that because if school.  and they took maybe 2 weeks to build.  So maybe 3 hours per axle.  If i new what i was doing it would have taken less time.
burnyota
_HOIST_
Hyena
