Project: More Clearance 2- INSTALLED!!!
Started by Hyena, January 06, 2005, 08:14:19 PM
Jack8542
 :drooling: those axles are lookin sick. :drool:  the whole no money thing works great when doing totota axles everything is cheap i love them :turtle:  :turtle:  :turtle:  :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
Im pretty much done with the front axle.  Just need to clean the housing and third.  If my truck doesn't sell they might just go on it.
MidgetMike
Is that thing done yet  :flamer:  How about you bring it over an I test it for you  :hammerhead:  :thumbs:  :gap:
I will have to pass on that one!   :hahaha:
MidgetMike
Quote from: Hyena on January 27, 2005, 04:37:36 PM
that's all right I like pushin rocks out of my way anyhow  :moon:
I got the rear axle clearanced.  I cut the bottom off and plated it, welded it inside and out.  Did that faster then the front, only took me 2 days!(at ashool)   I still need to plate the back of the diff and grind it all down, then put in the new fill plug up top.  Hopefully they will be leakproof!   :crossed:
Everything is done except for grinding.  I need to grind down everything.  I cut the shock mounts off, they were welded on crappy by who ever had the axle.  I need to fill in some divits i made with thr torche.  I somehow managed to break a bolt in one of the bottom holes.  It wouldn't turn anymore and it wouldn't come out, so i used force and it just broke.  We drilled it out and tapped it, and it seems to work now.  Im thinking these are gonna go on my truck, cuzz i can't get what i want for it.  I am going to keep my 5.29's and detriot.  but the detriot will go infront, im gonna weld the rear.  And i will hopefully have longfields by then.
rear housing done.  the red is paint from my bed, not rust.
more.  Drain plug moved to top for new fill plug.
last one.  The inside.  Then the two axles together.  Front housing is right side up, rear housing is upside down.
I just need to get some longs, new U-Bolt flip, and then we can put them under my toy.
They must suck badly if no one is replying.   ???
dirtbag
looks good, Brad. Too bad they're going under YOUR 84  :hammerhead: :thumbs: :bowdown:
Shaaddupp!  Well, at least someone replyed lol
MidgetMike
Thier lookin sweet, I'll go wheelin as soon as I get a belly pan and install my sterio, the sterio is'nt reqiured but my girl bought it for me last summer and it still isn't in and she's a little pissed  :smack:
I would die without my cd player.  Thats the only thing i got since my antenna is broken, i can't get any radio stations.
dirtbag
at least you have a radio in your rig right now......
Yota4life
Looks good, so how much more clearence did you get? Im guessing about an inch or so?
About an inch on the dif cover part.  And where the third mounts about 1/4 to 1/2 of an inch.
dirtbag
And your just jealous cuzz i have a toy that runs!    :respect:
dirtbag
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
Mike D
Hey dude don't forget to clean off the welding splatter so that don't kill your gears :flamer:
Jared
i got some axle housings today at the local pick n pull. anything you recommend for i start hackin away at em?   Im gonna be using a plasma cutter to cut the axles up... What would make this easier for me since you already did it brad?
TacoRunner
Jared:    If you have an extra 3rd   lying around it would be a good idea to bolt-it-up the housing when you start doing your final welds, so that housing does not warp from the heat.
www.4WHEELUNDERGROUND.com
[email protected]
I bolted a junk thirdmember up when i did the fianl welds on mine.  It didn't bend, so you should do that.  The main part that i am worried about is it leaking.  Just try to make the welds good so they don't leak.  I haven't tested them out yet for leaks, i am just gonna put them under and hope for the best.
