Author Topic: v6 diff head aches  (Read 2047 times)
topkicktech
  • Member since Apr '08
v6 diff head aches
« on: Nov 16, 2010, 06:42:55 PM »
 ive been trying to set up my v6 diff for a few days now i started with a .085 shim and the pattern was to deep i then went to a .078 shim and still to deep. im now at a .064 shim and im still to deep. i have a 12"lbs preload on the pinion and .010 back lash. the total preload of the assmbly is 25"lbs. im concerned that the pattern is very narrow. its not a wide set pattern like i have seen on other gears builds. im also concerned about how little the pattern moves with each change in pinion shim. there are some pictures of what the gears looked like with the .068 shim. also i am loading the carrier when im rotating the carrier with the paint on them. thanks for any help.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: v6 diff head aches
« Reply #1 on: Nov 17, 2010, 02:56:47 PM »
Are you sure you have the pinnion bearing races seated all the way down?
Dr Phat
  • Turtle Points: 305
  • Member since Oct '09
« Reply #2 on: Nov 17, 2010, 05:17:36 PM »
^ This
I needed to beat the crap outta mine to get it to seat down properly in the housing.
topkicktech [OP]
« Reply #3 on: Nov 17, 2010, 05:26:10 PM »
Ya I double checked that today. I've taken more shim out of the pinion and I'm starting to get a decent pattern. I think this gear set is just trying to drive
Me crazy
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
« Reply #4 on: Nov 17, 2010, 08:14:43 PM »
From what I have learned, different gear sets by different manufacturers require different pinion shims.  ZUK has said this several times.  FYI here's his cheat sheet. http://www.gearinstalls.com/cheatsheet.htm
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
OOPS
  • Male Posts: 2,561
« Reply #5 on: Nov 17, 2010, 08:42:37 PM »
^ This
If you put the races in the freezer for a few hours or overnight they go in a lot easier. we used to blast them with CO2 fire extinguishers that also works great on your beverage of choice.
tanabuse
  • Turtle Points: 4
  • Male Posts: 185
  • Member since Dec '09
  • sleeper, any time any trail any where
« Reply #6 on: Jan 20, 2011, 06:57:09 PM »
also you Do you know that there are factory 4.88  diff that wont accept any aftermarket gears at all he talks about it on the zuke site look around for it he says those diffs are wortless in that aspect
Turning
Over after
Years
Of
Trail
Aabuse
Last post Jul 22, 2004, 10:58:15 AM
by YotaYota
Last post Apr 05, 2005, 12:57:07 PM
by Rebeltilldeath3
Last post Nov 04, 2005, 07:02:27 AM
by 4runnerfromhell
Last post Dec 13, 2005, 09:15:53 PM
by jimbo74
Last post Mar 30, 2009, 10:10:51 AM
by oddball
