Author Topic: 85 22RE head vs. 84 22R head  (Read 6459 times)
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« on: Dec 01, 2005, 02:03:26 PM »
Quick background, I've got an 84 4Runner with a blown up 22R.  I just bought an 85 4Runner for cheap ($375  :greengrin: ) with a 250K 22RE that needs a rebuild.  The guy said the head might be ruined on it.  Are the heads swapable from the 84 22R to the 85 22RE.  I want to say no but I needed the expert opinions here first  :beerchug:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: 85 22RE head vs. 84 22R head
« Reply #1 on: Dec 01, 2005, 03:26:41 PM »
i forget... contact kyle 22r he knows ;)
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
« Reply #2 on: Dec 01, 2005, 05:39:36 PM »
yes....they are swapable, the only difference between the two are the shapes of the exhaust ports, and the cams, other than that, run it
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #3 on: Dec 01, 2005, 06:50:52 PM »
NO!  they are not swappable!  the early engines have a short head and the late engines have a taller head, which leads to your timing chain either being too tight or too loose depending on how you mix and match them together.
also, early('81-84) engines had domed pistons that'll most definitely smash into a late style head which is meant for flat-top pistons.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #4 on: Dec 01, 2005, 06:59:09 PM »
Kyle's right here.  The early heads are open combustion chambers (looks like a O) and the late ones are closed (looks like an 8).  typically, 81-84 will interchange with each other, and 85-95 will interchange with each other.
crawlerdan
  • Male Posts: 4,770
« Reply #5 on: Dec 01, 2005, 07:07:52 PM »
well.....ok then.....ive swaped a carb head onto an efi block but not the other way, guess i was wrong :_oops:
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #6 on: Dec 02, 2005, 09:03:52 PM »
well if it was an efi-carb '81-84 or an efi-carb swap from an '85-95 block it's no problem.  the head/block/piston interchange is a year issue, not an issue of efi or carbureted.  a 22RE is just a 22R with a different intake and distributor.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #7 on: Dec 03, 2005, 07:56:24 AM »
:nope:
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
  • So many yoda's, so little time!
« Reply #8 on: Dec 08, 2005, 12:56:46 AM »
PM me, i have an extra head.  It was run with out oil, so i am not sure what kinda conditions its in.  It will need to be sent to the machine shop!  I am doing mine in a week or two, so if you want it maybe we can send them both to the machine shop, than I can ship it to you.
PZ
92 xtra cab, with some stuff...
...why buy when you can build?
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #9 on: Dec 11, 2005, 07:35:41 PM »
a head run without oil is kind of a concern.  main thing there being that toyota didn't use cam bearings, the cam just rides directly in the cam journals.  that'd be the only way they could've improved on their valvetrain oiling system.
  • Male Posts: 8,707
« Reply #10 on: Dec 13, 2005, 09:15:53 PM »
not wrong, but not correct eother... if the 22r was from an 85 or later, then it would swap with a 22re no problem, but the early pre85 22rs were much different... as others have said
Last post Jul 01, 2003, 07:17:20 AM
by toyotaboy
Last post Apr 05, 2005, 12:57:07 PM
by Rebeltilldeath3
Last post Nov 29, 2005, 07:19:12 PM
by hdrisc
Last post Mar 30, 2009, 10:10:51 AM
by oddball
Last post Nov 20, 2021, 01:47:36 AM
by Brendan
