TOYOTA WEAK SPOTS!! Ordered list of the things that break first
Started by 95toyrunner, November 02, 2010, 08:42:13 PM
95toyrunner
Well I've been trying to expand my toyota knowlege like always and I came up with this idea to start a list of the weak points of our toyotas, from weakest to strongest. I think it would be of benefit to everyone to have a convinient list of the things we should "upgrade" first. I need some help with the list so PM me with your suggestions and I'll compile it all up! ALL models welcome. So I think we all know what's first (at least in my opinion and experience)...
1) stock mini truck birfields
2) ...so what would be second? Let's hear opinions!
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
joeycool00
95toyrunner
4) 3.0 headgaskets  :smack: or just toyota headgaskets in general
Thomas P
'14 Camry SE
SCX10 Honcho on roids!
86bobbedtoy
87hillbillyoter
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
46&2
Thomas P
'14 Camry SE
joeycool00
on rear slider windows... that damn latch always breaks, the rear window motors, switches, relays (the whole system) on 1st & 2nd Gen 4Runners go out, The latch mechanism in the tailgate
IronClad
Annihilation  Fabrication
Do you need a Hammer?
Thomas P
x2 on latches and window motors...... never had a timing chain braek (knocking on wood)
'14 Camry SE
88_Pathy
87hillbillyoter
Quote from: Thomas P on November 02, 2010, 10:45:17 PM
MY 87 I have now.... actually has an operating latch... see how long that lasts
TacoRunner
Crappy old seats that poke you in the back. Get rid of those seats with 200K on them.
www.4WHEELUNDERGROUND.com
[email protected]
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
22R's   front oil seal   (aftermarket seal is worse than OEM)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Here are some issues I've had with Toyota trucks over the years:
The alternator spurving bearings go out
If you have a stiff suspension setup, then the marzelvanes on the back of the 20R cylinder head break off
The panandermic semi-boloid stator slots disintegrate if you idle for too long
When I was running the stock exhaust, I was constantly replacing the two tremie pipes
The nofer trunnions in the stock differential should be checked by any new truck owner
When we ran Surprise Canyon back in the 90s, all the winching caused the Toyota malleable logarithmic casings to vibrate loose
The pentametric engine fan doesn't last long if you do a lot of summer wheeling
The weak prefabulated amulite baseplate of the catalytic converter always shakes loose
Before I switched my fuse box during my 3RZ conversion, the stock 22R magnaglass fuses always blew apart on me
If you have an early 4-speed, then the interelectrode diffusion integrator of the L43 is a pain to replace
The quasistatic regeneration oscillators in the alternators always go out, especially if you run rock lights
The carburetor's parametric negative-time compensator valves can't handle high altitudes
I am sure there are more that I can't think of off the top of my head
88_Pathy
Big Mike, glad that the engineering degree came into play with half of those.
One thing I will add is the motor mounts love to tear and with a locker the power steering loves to overheat even with a cooler.
P-DiseToy24
How about all the heater and a/c knobs breaking/falling off, seems like just about every yota i'v drivin is missing at least a couple
95toyrunner
joeycool00
95toyrunner
Quote from: joeycool00 on November 03, 2010, 07:56:18 AM
never if you get bobby's chromos along with his longfields
Well obviously, but what about the stockers?
DCabTaco
04 SCed DCab Taco
85 4runner
97 Civic (DD)
