Author Topic: how do you make 63's stiffer?  (Read 2411 times)
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« on: Oct 27, 2010, 12:50:08 PM »
i have a set of 3 leaf pack 63's with the over load taken out in my 85 reg cab with a 3 in. block under them.  has worked great for years.  only complaint i have is when i have all my gear loaded in the bed and out on the trail, it's constantly bouncing off the bump stops.  without the gear, no problem, but when there is about 150 lbs or so of gear back there, its horrible.  anyone know of a good leaf to add to the pack to make it hold more weight?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Rocksnail
  • Turtle Points: 3
  • Male Posts: 595
  • Member since Jun '07
Re: how do you make 63's stiffer?
« Reply #1 on: Oct 27, 2010, 01:50:23 PM »
When i put 63s in my buddys 3rd gen, i added the second leaf from top out of a f150 pack, seams to work very well. didnt mess with his flex but helped with the load. Or put an over load back in it and maybe trim it down some?
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
superyota [OP]
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #2 on: Oct 27, 2010, 01:54:25 PM »
i'll try the f150 leaf.  i don't want the overload in there.
ABD Motorsports
#4475
KK6QDW
lownlinked85
  • Male Posts: 408
  • Member since Mar '08
  • Yeah Baby!!!
« Reply #3 on: Oct 27, 2010, 02:33:52 PM »
what about an add a leaf from 4 wheelparts? Is that an option?
Low locked and ready to rock
superyota [OP]
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #4 on: Oct 27, 2010, 02:49:06 PM »
would you get just a stock add, or some kind of a lift spring add?
ABD Motorsports
#4475
KK6QDW
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #5 on: Oct 30, 2010, 08:34:38 PM »
Stiffen the compression dampening on your shocks. A lot.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Japjeep
  • Turtle Points: -23
  • Male Posts: 119
  • Member since Oct '10
« Reply #6 on: Oct 30, 2010, 08:37:11 PM »
try chevy 54" lowwr pack
Japjeep
  • Male Posts: 119
« Reply #7 on: Oct 30, 2010, 08:38:34 PM »
sorry try the lower leaf in a chevy 54'in pack
Last post Dec 14, 2003, 08:32:43 AM
by 79coyotefrg
Last post Feb 09, 2004, 09:23:11 AM
by ToyotaMax
Last post Aug 28, 2006, 10:46:38 AM
by toyotamobing
Last post Nov 06, 2007, 04:27:15 PM
by skipnrocks
Last post Nov 20, 2008, 10:25:21 PM
by Volcom
