Author Topic: trail gear creeper breather  (Read 11093 times)
wingnut
  • Male Posts: 7
  • Member since Dec '08
« on: Oct 08, 2010, 06:55:42 PM »
I know this is probably not the place for this, but I need a lil' bashing.. I purchased one of trail gears "creeper breathers" and made a 50 mile round trip to my fav. wheeling spot and back. When I got home I was cleaning the bed out when I noticed something dripping from my shock hanger. I bent down and gasped at the sight of gear oil covering every square inch of my axle, bed, shocks, etc... This is the axle that I just installed Marlin's built differential w/ arb air locker. Front Ranges full floater kit w/ custom Longfields. To say I've dumped alot of money into this axle would be an understatement. If trail gears $20 part has harmed my axle I will punch a kitten right in the face. When I pulled their breather off there was an expulsion of air that sounded like I just pulled the purge valve on my compressor. Was wondering if anyone had ever used this product with same results or if mine was an isolated incident?
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: trail gear creeper breather
« Reply #1 on: Oct 08, 2010, 07:04:16 PM »
I would say toss that thing in the trash and run a vacuum line up to the shock tower with a regular ol' breather on it.
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #2 on: Oct 08, 2010, 09:12:41 PM »
A female end brakeline threads into those puppies. :] Im running brakelines out of mine with the male end cut off and im going to butt connect more tubing onto it and bring them way up out of the way with little breathers
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Member since Oct '10
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #3 on: Oct 09, 2010, 02:08:37 PM »
i would only run the trial gear breather on a trail only rig..where it does not heat up as much as a street driven car will..but u should do a leakdown test and make sure ur arb aint leakin!!!
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Oct 10, 2010, 02:39:11 AM »
I wouldn't run them at all, no need for them when a piece of rubber hose and a brake line end is a better setup anyways.
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #5 on: Oct 10, 2010, 09:49:13 AM »
And they look like some kind of slinky is protruding from the housing...
yotatough
  • Turtle Points: 16
« Reply #6 on: Oct 10, 2010, 10:55:11 AM »
I never saw a need for them. Just like everyone else, just run some rubber line up under the bed.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #7 on: Oct 10, 2010, 02:21:23 PM »
the only helpful thing in that creeper breather kit would be that barb fitting.
Tofudude
  • Turtle Points: -31
  • Member since Jun '10
« Reply #8 on: Oct 10, 2010, 10:51:50 PM »
for an extra 10-15 bucks you could of bought the breather tube kit from marlin
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #9 on: Oct 11, 2010, 10:03:52 PM »
so with all of your guys hoses what happens when you roll? your fluid ends up evrywhere, i run the same thing but with a mini air filter on the end of it. when i roll i still leak oil out.
i ran one of those breathers in the rear of mine and it blew the gasket sealer out of the third. on the other hand i know plenty of people that run them without a problem. but yes i would say they are best set for you front diff and/or on trail rig only
UA 342
STEAMFITTERS
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #10 on: Oct 11, 2010, 10:34:33 PM »
I put a fuel filter in the end of mine.  If oil makes it up that far atleast it will be absorbed somewhat..
  • Momentum Man
  • Lego Enforcement
« Reply #11 on: Oct 12, 2010, 02:41:05 AM »
I don't roll it, ever. :gap:
I stick the oem breather back on the end of the hose.
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #12 on: Oct 12, 2010, 07:48:00 AM »
i just hose  clamp the stock breather on top of a hose.that thing works pretty good!!
wingnut [OP]
  • Male Posts: 7
« Reply #13 on: Oct 20, 2010, 04:42:45 PM »
Yeah, I am running rubber tubing into the engine bay on my front axle, I just saw this thing and thought I would give it a try... I have now gone with the rubber hose on my rear as well (that just sounds wrong)
wingnut [OP]
  • Male Posts: 7
« Reply #14 on: Oct 20, 2010, 04:44:23 PM »
I did keep the barb fitting though
wingnut [OP]
  • Male Posts: 7
« Reply #15 on: Oct 20, 2010, 04:47:38 PM »
luckily the locker's not leakin
  • Momentum Man
  • Lego Enforcement
« Reply #16 on: Oct 21, 2010, 04:48:04 AM »
Good deal, some things are just ooooh that's cool looking. Kinda like a rear wing on a 4 door Nissan Sentra, some may think it looks cool but it is actually worthless.
Fleetwood
« Reply #17 on: Oct 21, 2010, 02:37:25 PM »
I run'em on my truck front and rear and have had no problems and no water in my oil. When installed i decompressed them slightly maybe that helped.
  • Momentum Man
  • Lego Enforcement
« Reply #18 on: Oct 22, 2010, 04:07:11 AM »
I don't run 'em and don't get any water either, just a cool factor add on as far as I'm concerned.
TractorDriver
  • Male Posts: 20
  • Member since Sep '10
« Reply #19 on: Oct 29, 2010, 02:59:12 PM »
I agree rubber hose is best never know when you may need it for somethin else!
Rock Tractor Racing
Gasss Ittt!!!!
Climbintathatop!
Special Thanks to: MarlinCrawler, Inc.
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
« Reply #20 on: Nov 17, 2010, 05:21:23 PM »
An 1/8 npt pipe fitting screws right in there. I just have a brass barbed fitting with a rubber hose runnin up to the frame. It runs about two dollars and you won't have that big old dildo looking thing bouncing all over your axle.
the-t-man
  • Member since Nov '06
« Reply #21 on: Dec 06, 2010, 04:22:10 PM »
i have been running them for 2 years or so, only time something like that happened is the arb seal housing or copper line rubbed a hole and pressurized the front diff..
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #22 on: Dec 06, 2010, 04:47:24 PM »
x2 :yesnod:
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #23 on: Dec 06, 2010, 04:50:17 PM »
x6
Last post Feb 18, 2007, 09:26:40 PM
by 4x4Haze
Last post Apr 26, 2008, 07:40:59 PM
by bonebuilt
Last post Mar 27, 2012, 07:20:38 AM
by dntsdad
Last post Aug 25, 2022, 06:05:50 PM
by sirdeuce
Last post Jun 07, 2024, 11:00:41 AM
by TV185
