Mall crawler 83 build 3rz swap
Started by 83 Crawler, August 21, 2010, 11:58:46 PM
what should i do next?
tires
16 (22.2%)
duals
56 (77.8%)
Total Members Voted: 72
83 Crawler
No thank you I love my square
gnarrkill
79 toyota duals,caged,40 mtrs
the build thread i dont update
http://board.marlincrawler.com/index.php?topic=65367.0
83 Crawler
gnarrkill
Quote from: 83crawler12 on March 28, 2011, 11:31:40 PM
I'll still take them
i think were going to browns the 16th for mine/dustins bday come up and hangout
83 Crawler
Ya hope fully my ifs axle is on and my locker up front
83 Crawler
so now that i got a job the build is starting again, i already got 2 cases so i just gotta buy the adapter and 30 spline in  put and output and 4.7s,crossmember and put in my front 529 diff and weld the rear one buy 30 splines and 37in km2s and rebuild my motor
83 Crawler
well got some new doors and top shift case for duals today
daniresch
are you going 21 or 23 spine for the rear case?
adapter clocked 10 degrees, or straight?
i'm piecing my dual setup together right now too :willynilly:
83 Crawler
I'm just doing 21 spline and not clocked I really don't wanna go flat belly but we will see I'm trying to findva daily driver right now
daniresch
I have a dual case cross member if your not running a clocked adapter  :thumbs:
built your crawl box?
83 Crawler
painted it back green and did some small stuff to it
87hillbillyoter
looks badass, i liked the red! i love the look of the first gens on big tires man,  :drooling:
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
83 Crawler
Thanks alot man and I'm running 35s but I wanna move up to 37s
83 Crawler
Alright the only bad thing is allnthe bolts insidethe  frame are breaking so idk how I'd run one
daniresch
can't you add another bolt on top?
daniresch
if you think you can make it work i have it just sitting in my garage :beer:
83 Crawler
on hold cause i have a charging problem and its getting really old took the alt in and had it tested and it passed so then i changed voltage reg and its still only charging 12v
Muddytazz
Ryan, check a clean all grounds and connections in your charging circuit and your battery connections.  Doing that is free before you have to look at other options.
Build it right or get off the trail
83 Crawler
Alright Jeff I'll do that tomarrow and let you know
83 Crawler
Ought a dail driver no more Toyota every day for ne
gnarrkill
Quote from: 83crawler12 on June 06, 2011, 09:31:31 PM
maybe you can take up some typing classes to with all that money you save from gas to...
4x4yota
If your still having charging issues check your charge lamp relay
Current:
Sold:
83 Crawler
I fixed it it was my damn engine fuse
4x4yota
Current:
Sold:
83 Crawler
Yes it was and bought a new truck so I can work on it more
