Mall crawler 83 build 3rz swap
Started by 83 Crawler, August 21, 2010, 11:58:46 PM
what should i do next?
tires
16 (22.2%)
duals
56 (77.8%)
Total Members Voted: 72
83 Crawler
i might have a bench seat, its been at a buddys house for awhile, ill see if its still nice, and ill ask around for sure
83 Crawler
well got the duals i bought torn apart and ready to be put back togather once i buy the adpapter and 4.7s..
yotaneck13
you should really tear that kind of stuff apart on a bench or table top not just tear into it on the floor and scatter parts thats ho snap rings and spacers get lost and forgotten then reassembled with out and causes a lot more headache :thumbs:
83 Crawler
Got every in baggys it was perfect,
Anybody wants to buy a tg. Dual adapter?
yotaneck13
yotaneck13
83yota
patches
Glad to see its coming along. I'm just waiting on brake plate elims and I can finish the front end for now
I don't trust anything that bleeds for 5 days and doesn't die....
patches
83 Crawler
ya im going to to redo whole front axle, and rear axle with new 529s to :)
patches
Yep my front end will be 100 percent fresh. Hopefully it holds and I did it right
BHT12
I have seen a few people cut out the drain plugs or like you did shave it on the axles.. im guessing so you dont beat it up on the rocks but.. how do you drain the oil?
1984 4runner. Trailgear fronts, custom backs with shackles, 36 iroks, hi steer, hybrid 20+22r motor, full exhaust, lowsy weber, power everything, rear heat, power Antena,  sr5, altimeter,  back seat eliminator, tube bumper
1981 2wd long bed parts getter. All stock, sr5
1983 Toyota Sandtana Motorhome 4x4 Stock.
yotaneck13
you can make youne of your diff studs a bolt and drain the oil that way much easier IMO than pulling axels and the 3rd everytime you wanna change gear lube
BHT12
That's a good idea. Pulling the third evertime to change the oil is a lot of work for something that should take one bolt.
yotaneck13
itll drain slow since the diff studs arent very big  and dif oil is thick but it works good and saves alot of time
BHT12
83 Crawler
its not like you have to change gear oil all the time? so im not to worryed about it, and my buddy still has his and it gets beat on so much he cant get a wrench on it to loosen it
yotaneck13
I'm big on maintenance .  so i change it religiously.  Just me i hate :pokinit: breaking that's all.
BHT12
i try to change all my fluids when there suppose to.. my grampa made me a believe when he changed his oil ever 3,000 and his toyota was at almost 700,000 when the oil lines cracked and started a fire... no rebuilds either
83 Crawler
so im changing direction on the build im going to keep springs power steering high steer front axle and t case from my first gen and start building my 2wd 3rd gen, once i get another daily driver, hopefully a 4 door 4runner, so i prob wont be wheelin for awhile
daniresch
