remove thermostat and see what happens
check the water pump you may have a restriction like a rag or a wasp nest that the rag was supposed to prevent while the motor was sitting around just a thought if the thermostat checks good
You didn't put the thermostat in backwards did ya?
......... I'm just confused as to why the radiator was basically "cold" while the engine was clearly getting hot...........
my 2rz runs at 210 give or take 5degree at all times. ive had a 3.0 rad in it now an aluminum, and 2 different e-fans and nothing has changed more than a couple degree. i remember i tryed taking the t-stat out and it would run 180-190 so im thinking of doing that again
Started by jrock Engine
Started by norcalyoter Engine
Started by jrock Toyota Pickup/4Runner Tech 1979-95
Started by jspd234 Toyota Pickup/4Runner Tech 1979-95
Started by tho1981 Toyota Pickup/4Runner Tech 1979-95
