I wouldnt even bother with the boomerang shackles. Even if they are not hitting the frame sitting when you hit a bump or even turn they will likely hit. The best and most correct way to correct this would be to get a drop front hanger which could be welded on the 1" or so forward. This would correct your shackle angles as well as move your front axle an 1" or so forwards giving you a better approach angle. Then again if your gonna go that far then you mind as well do a rears up front setup.
yeah im thinkin about the bomerang..... but these shackles now are 6" bolt to bolt, i think the boomerang would have to be like 8" bolt to bolt to even help at all... which is extremely long i would think. on the boomerang would you recommend start the bend of the shackle 2 inches after the frame bolt? or begin the bend in the middle of the shackle? thanks man
Started by Gearhead Wiki Project Research and Build-Ups
Started by wrenchtech Parts Wanted
Started by slabcrawler Parts Wanted
Started by 95square Engine
Started by Fo-runna Parts For Sale
