Well, im selling off my toyota. you can check out the build here
http://www.pirate4x4.com/forum/showthread.php?t=728504&highlight=beat+street . what all im selling is the chassis (cab which is green stickered with title until 2011, frame, wiring for the 22re, its set up for a 22re/w56/duals flat belly, i have the drivelines, all the links stay, 4 link front and rear, the rear 14B 4.10 welded with discs, front 4 linked chevy D60 with WFO high steer, double ended ram, fab cover, missing short side shaft and stub and lockouts, new bearing, 4.10 welded, also comes with the orbital lines, brake lines, steering fluid reservoir, front is set up for 16" SAW coilovers, and its made for a M8000 winch, im sure others will fit, rear is in the process of being backhalfed and is missing the fuel tank, interior has a full dash and SR5 cluster, all glass except windshield, but the cab is in good shape and holds a window no problem.
honestly its everything except the engine/tranny/cases, shocks, fuel cell, and needs the back half finished.
the front axle has about $1800 into it by itself the way it sits ($800 axle, $250 steering ram/lines, $100 diff cover, $500 steering arms/tie rods, $200 bearings, etc) not to mention a $400 orbital, custom frame, 16 creeper joints 2.5x.375 DOM links. rear axle it 100% complete and ready to go. 1 ton brake booster......theres kinda a lot of
![Pokinit :pokinit:](https://board.marlincrawler.com/Smileys/marlin/pokinit.gif)
on this thing still.
its all in chico, im taking offers for sure. give me a call.
BTW, the exo is gone
Callen
530-321-9905
