Beat to death, but SAS?
Started by BLACKDOG, April 18, 2005, 10:21:35 PM
BLACKDOG
#60
cool :thumbs:
what I was looking to hear.  going to bigger M/C, do I have to get complete new lines?  I'm not big into brake work, so I dont know much about it.  I just change them, thats about it so far.
anything else you guys have would be awesome.  If the fullwidth 60s arent too much harder to do than a toyota swap, then I'll probably lean toward going that way :yupyup:
just a guess, but my mpg is gonna go out the window huh?
              -Ronald Reagan
IronClad
for the M/C side  you will have to reflare  the lines to run a 3/16ths nut  which aint no thang really.  for the axle side you can get some braided SS brakelines made fairly inexpensively  from a speed/race shop  in whatever length you want ( buddy of mine has 40" long SS braided lines !!!)   really the only thing thats truely  extra  to doin a fullwidth conversion is a flattop knuckle if you ever swap in a 44  but if you go 60's you dont have to worry about that.  I dont know of any premade steering kits for a fullwidth conversion on a toyota since it varries so much  truck to truck.  but steering is easy to build..   if you have any questions feel free to ask
Annihilation  Fabrication
Do you need a Hammer?
BLACKDOG
I just noticed that you were in Oroville, mabye over the summer, once I get my parts togehter you can come give me a hand, and some advice while I'm at it?  I'll buy the pizza and beer :yupyup:
kind of a sidenote, but my a lot of my g/f family lives in Oroville.
              -Ronald Reagan
guywithuglyyota
Yeah i didnt mean to hit a soft spot with the D44 guys. I have just seen many more D44's fail than yota axles. And this was on Jeeps, with much more torque than a yota can put out, unless your running duals. Also, us die hard yota guys are a little more biased toward yota parts etc.... In all actuality ANYTHING can break, couple weekends ago I saw a Dynatrac Dana60 break its ring and pinion towing a samurai! Run what you have and have fun with it.   :beerchug:
the medeocre guy
BLACKDOG
lkinda what I am figuring.  And in my $$ situation, I'm thinking the stronger stock the better, because I cant buy preformance parts right now on my budget
              -Ronald Reagan
IronClad
Quote from: BLACKDOG on May 04, 2005, 11:34:05 AM
Sure thing iffin im not  super busy or anything
BLACKDOG
yeah, hopin I wont be to busy either.
that'd be cool, but dont worry, I'll be hittin you up for advice for sure :yesnod:
what are you talkin about, flat top knuckle for a 44?
              -Ronald Reagan
If you plan on putting a dana 60 in the front you should start searching now.  they are really expensive.  As in over $1000 for a good working axle.
1tonCroozer
No soft spot at all with me. I know what I put in and wouldn't change it either.
Stock for stock...a D44 does beat out a stock birfield in strength. You can read the other positives for using Dana stuff to in my last few posts. If you have seen more broken D44's than Toy's.....and more than likely if it's a Jeep it's a D30. Old school CJ's had really weak parts and the newer YJ's, XJ's and TJ's have D44 u-joints, but the inners are still smaller and so are the outters. (This why they are D30's) So I don't think your seeing alot of busted D44's under heaps.
D60's are $$$, but when your talking money, in the end it costs about the same to build a Toy, D44 or D60. The stock D60 is the strongest stock and you'd have to dump about a grand into a Toy axle just to hit the stock D60 strength...and where do you go then?
Using Toy only parts? Well, if that is what your after! Sounds like Landcruiser guys though. They are hardcore Toyota freaks until the breakage gets old. In steps Dana.  :love:
guywithuglyyota
Well thanks for just making my point with the soft spot. I was going to give you a drawn out explaination about how I have seen D44's fail but Im sure your just going to say Im wrong anyway....    :shake_head:
hudlenutz
I have to throw this in because of the Dana/keep-it-Toyota discussion.  I mentioned this over on the drivetrain page, but here it is again.
How about using an 80 series Landcruiser axle?  The birf on a cruizer axle is one inch larger in diameter than one the trucks/runners.  It's like a one ton Toyota axle.  I searched some of the yard pages, and you can get entire assemblies for~$850ish.  It seems pricey, but the 80 axle is already high pinion and had the optional electric locker (already cheaper than upgrading a mini axle).  I think it's full width too, at 4 inches wider than the ifs.
Good luck either way.  I know people have had all kinds of luck with all sorts of different axles (unimog reduction hubs???).
:beer:
1tonCroozer
